Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Like Tree3Likes
Thread: 308 vk commodore
    ve commodore sv6
    May 2011
    australia
    Default 308 vk commodore
    hi guys...
    just want to know what is the easiest way to start my 308(red) engine without using the loom as not being put on the road...as this is what we have done
    got a vk comm with a black 6 not injected...put a rebuilt 308 and turbo 700 trans in it...all nicely fitted...
    my problem is i am not getting spark and dont know which wires to use from the old loom (6 cyl loom)...any help would be good....cheers
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    to start the 308 u just need a fat lead from 12v (+battery) to the starter motor...and a earth lead from the starter motor to earth
    and hen pretty much the same for a altinator
    i think
    oh edit: and wire it to a ignition so u can stop and start it
    with the 202 and not gettting spark is the firing order correct
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    may be a dumb ? but do u have any spark when u remove a lead from the plug??
    ve commodore sv6
    May 2011
    australia
    no there is no spark at the plugs or points...putting new condenser on it tomorrow...really want to know what wires to use from the 6 cly loom
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    if your not gettin nething from the plug! start backtracking to your dizzy rotor, then the coil and so forth you may have lost somethin along the way...is everything going to ground?
    RVK 355's Avatar
    RVK 355 is offline M0DERAT0R
    The real R series 355
    Aug 2006
    ther should be a big pink wire in the VK engine loom, that goes to the posotive side of the coil
    ve commodore sv6
    May 2011
    australia
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by lindsay1 View Post
    without chasing your tail too much just grab a gregorys wkshop manual..they have all the wiring schematics and are colour coded too and are pretty straight foward to read if u have abit of nouse! the 6cyl main wiring harness comin from your ignition shouldnt be 2 diffrent...from memory mine had 4 wires in total on my vh..which is an 8. the 4 biggest wires are the main ones to get it runnin all the other lil ones are for your temps,oil. ok from ignition barrel is red to a main fuse, to your +batt then to your starter, from your starter to a normally open circuit relay which closes circuit to supply power to your ignition setup! once it gets to there its all 2wires maybe a 3rd which are red&blk or brwn/black...black always negative. without seeing it its hard to sus it out...but u should lable the termination point of each wire so u couldve referred back to it to rewire! but yeah go the wkshop manual..its a no brainer
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    ok but how many wires come from the dizzy and where do they go???
    should be 2from the diz..1 definately goes to the coil not too sure about the other..it may do too! ........shit i only removed the harness and ditched it from my 308 2wks ago. i knew i shouldve took note as to what went where!
    try this it may help for labeling as what is what...i know it says hz
    but it is all the same
    http://cgi.ebay.com.au/ws/eBayISAPI....m=370443581305
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    ve commodore sv6
    May 2011
    australia
    this is what is happening...can turn engine over by hitting starter but there is no spark....when we try with the key you just hear a click in the relay box...i have heard of a 3 wire setup so would that work and it is a carby engine not injected...
    ve commodore sv6
    May 2011
    australia
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    gota multi meter?
    does it run nonstop when u hit the starter? or does it just crank over?
    theres 3 terminals at the starter...there is a nut type(red from battery) terminal and 2 spade connection terminals...on the harness find two spade connections (they should be paired 2gether)- maybe a black and purple! black is (-).
    ve commodore sv6
    May 2011
    australia
    just cranks over...not throwing a spark thats why putting new condenser on it and need to know where 2 wires from dizzy go to...
  15. #15
    ve commodore sv6
    May 2011
    australia
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    condenser??? the 2 from the diz go to coil! there should be 3 connections on the coil! 2 of which are for the diz and one is from the supply power. mine from the diz has one spade connection and 1 ring type..the ring type goes to the connection at the coil which stands alone. and there should be 2 connections side by side or bridged together in some way!...sorry man i dont think im helping really...if i was there lookin at it ...it would be runnin
  17. #17
    ve commodore sv6
    May 2011
    australia
    the condenser goes inside the coil...as for the 2 wires from the dizzy is one pos and one neg and is it the big pink wire that goes to the pos on the coil...
  18. #18
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    hehe. what a random thread.
    to start with, OP, you said there is no spark at the points?? so is it a points dizzy? if so there is only one white wire (i think) which goes to negative on the coil [need to confirm that] if its points, you will need to make sure the balast resistor is working properley too.
    if you got a HEI dizzy, two wires (as mentioned) black and red, obviously black - and red +. but somtimes itll be green and purple and i believe green is - and purple is +
    from the loom that comes out of the drivers side of the firewall, you will need just two. a fat pink and a brown, the fat pink is ignition 'on' AND 'start' and the brown is tacho. now the tricky bit with the pink is that if you have a dud tachometric relay or blown fuse, that pink wire will only get power on ignition 'on' and itll switch off in the 'start' position, which means you will crank and crank and nothing will happen, but when you check it with the ignition 'on' itll show as having power. that stupid wire got me once too really badly. took 2 days to figure wtf i had done. so go check that first. stick a test light on it, then turn the car to 'start' and if the light goes out, theres your problem.
  19. #19
    vn
    Nov 2009
    noble park
    as its a points distributor and you only want to start it wire from positive on the battery to positive on the coil with the 1 wire from the distributor to the negative on the coil and screwdriver the starter.
    this will do for a short time, with out the resistor the points will turn blue pretty quick. you may need to power up a solenoid on the carby to get it to ideal cant remember how quaddies go haven't touched a v8 for a while.
  20. #20
    ve commodore sv6
    May 2011
    australia
    i put a new balister on the dizzy and yes it is points...when we crank with starter motor we now get spark...but what i face now is i cant crank it with the key and the elec fuel pump is not turning on...do you know what wire and what colour it is for power to pump and any ideas on the starting with key...thanks...
  21. #21
    ari666's Avatar
    1966 impala
    Mar 2009
    what kind of elec pump is it? power is usually a 7.5A fuse in the rail, but if its an elect pump off a EFI 6 then there will be WAYYYYYYYYYYY too much pressure for a quaddy.
  22. #22
    ve commodore sv6
    May 2011
    australia
    the motor that came out was a black 6 not injected and the guy who took it out pulled the wires...in the fusebox under the bonnet it says for the pump its number 4 but when you look in there there is nothing in there to hold the fuse in....and i know the pump worked when the other motor came out....also any idea on why its not cranking with the key...does it need 2 blade connecters for the starter...
  23. #23
    ari666's Avatar
    1966 impala
    Mar 2009
    the pump will need to be hooked to the tachometric relay. best idea is to hook up the mechanical pump that came off the engine you have, if its a points engine, then itll have a mechanical pump.
    problem solved.
  24. #24
    ve commodore sv6
    May 2011
    australia
    it does have a mech pump on it...but i still need to know why it wont crank with the key...dont want to keep trying to start it with a screwdriver...
  25. #25
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Have u got it in "P" for park? Or neutral, does the neutral safety switch work? Is the power getting to the ignition, is there power coming out of the ignition (purple wire I think), have u tried the starter solenoid wire on the different terminals on the solenoid?
    Put a test light on the starter wire going to ur solenoid, get someone to turn the key and see if there's power getting there. If there is, tap the solenoid with a hammer incase it's stuck and try again, if still no go maybe it's rooted?
    If there ISN'T power at the solenoid just work ur way back. Try the input and output of the neutral safety switch, if power goes in but not out, then ur switch is dodgy, either replace it or cut the wires and join them lol. If there's not power at the switch at all, check the ignition.
  1. [VIC] FE2 Suspension setup for VE commodore @ Ultra low King Springs for VE commodore
    By IGNITIONSV6 in forum Parts And Other Items For Sale
    Last Post: 05-09-2010, 02:39 PM
  2. will a vx commodore ecu work in a vt commodore
    By lestat2220 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2010, 10:05 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
