Hey Guys,
Reaching out for some advice!
Ive just reinstalled a manifold on a new engine I purchased, but forgot to put sealant on BOTH sides of the gaskets for the coolant passages. Will this be ok ? , or do I need to take the manifold off again...and if I do have to remove again, can I reuse the gaskets, since the engine hasn't been run yet ? They are OEM gaskets.
Its a VR 304, with std manifold.
Any advice would be greatly appreciated!!
It'll be fine. I never use sealant on inlet gaskets.
If you have to use sealant, there is something wrong with the gaskets.
Thanks very much, thats gives me a bit of piece of mind...
