hey guys ive got a vn v8 calais sv enhanced
it has a 248 cam in it
question i want it to sound more lumpy how would i go about doing this exhaust? if so what kind of exhaust?
cheers sam
Well what exhaust is on it now? 3 inch springs to mind but you can lose back pressure. But it will sound better... But a bigger cam and tune will fix this issue also![]()
Had a twin 2 1/4 on my VN no rear reso sounded loud and lumpy with the cam
As above what exhuast is on at the moment? And just to clarify.. You do not want or need backpressure... backpressure prevents the exhaust from evacuating the cylinder and leaves residual gasses inside which prevents a full intake charge from entering the cylinder, this gets worse as RPM increases..
Best system, or what i like is (extractors, twin 2.5" pipes, twin cats (standard holden ones will do), merge, twin mufflers, then merge into single 3" around the diff then use a resonator ) A resonator will take any shit droning out and also will stop it sounding like a tug boat.
