Results 1 to 8 of 8
Thread: inlet manifolds for 304 vt 5L
    vg ute
    Jun 2010
    shepparton
    Default inlet manifolds for 304 vt 5L
    im looking for a inlet manifold for a vt 5L as in one that flows more better than the stock one. all i have done atm is hsv memcal and twin 2.5" cat back.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VH SS
    May 2009
    Toowoomba, Qld
    what sort of mods to you have in mind for the future ?
    because if you don't have any real big plans, you are better off keeping the factory manifold. They are probably the best all round manifold for an engine with only mild modifications
    vg ute
    Jun 2010
    shepparton
    as of now has twin 2.5" red back cat back with all mufflers still, and a 195kw hsv memcal.
    furture mods are extractors, hi flow cats, stage 2 cam maybe ported heads, mace cai and polished tb and maybe bigger rockers. if i was go all out id go down the path of strockering it. for now this wont be happening for abit though. been told might need a straight 3" exhuast though if im going to cam it. but i'll lose power with a 3" atm.
    was trying to find the manifold that looks like stock but flows more air forget the name guy in shepp had one on his vq reckons was best thing he done for it.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vg ute
    Jun 2010
    shepparton
    dont ask me thats what they call it at super balance they go stage 1 2 and 3? only after a mild cam and they said that's a stage 2?
    VH SS
    May 2009
    Toowoomba, Qld
    the old Starr Manifold looks completely stock, except it the neck of the manifold has been modified to fit a 90mm throttle body. Some reasonable results from these on strokers, although they still aren't great for making power at anything much higher than 5500 rpm, due to the design. But as opposed to most of the other aftermarket manifolds, they do maintain very impressive low to mid-range torque.
    Starr doesn't sell them anymore, but but these guys do
    http://############/vn-vs-starrmanifold.php
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    starr manifold aint worth it - while your car is still close to stock your best to hit up mace and get a 70mm throttle and bore your neck on the manifold to 70mm
    unless you do H/C or stroker get a come twin throttle manifold
  1. 304 plastic inlet manifolds
    By sam5l in forum V8 Development and Modification
    Last Post: 27-03-2010, 05:31 PM
  2. vn v8 inlet manifolds????
    By kiwi pup in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2009, 09:43 AM
  3. vn and vp v6 inlet manifolds
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2009, 07:03 PM
  4. Inlet Manifolds
    By Phantom VK in forum V8 Development and Modification
    Last Post: 13-08-2008, 09:25 PM
  5. EOI: Polished Inlet Manifolds
    By IMCRZY in forum V6 Development And Modification
    Last Post: 01-05-2007, 07:11 AM
