Hi Guys
Just wondering if anyone out there would know as I can't find anywhere on this forum as how to install drive/fan belts on a vr ss v8 either be it by diagrams or by explanation all tips will be of greatful help.
Well to get the PS belt on I always get it on the PS pully just a bit then crank the engine to get it to pull itself on.
As for how they run im not sure VR but VN ive got them going like this,
1st belt, crank -> water pump -> alternator
2nd belt, crank -> water pump -> PS
3rd belt, crank -> idler pully -> AC
Well thats how I remember them, since now ive only got a need for the first belt.
The Daily VN T5V6
355 VN GRP A REP
Just a tip. Its all so much easier to do if you pull out the clutch fan, shroud and radiator. Makes for a good opportunity to back flush the radiator, replace hoses and fill her up with fresh coolant too.
Just replaced the radiator on my VT, bit different i know cause VT has thermos... but the clutch fan on a Vr can be a pain too. I bit the bullet and replaced all belts while the front of the engine bay was clear
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
