Results 1 to 10 of 10
Thread: EFI 304 running like a barge under full throttle
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default EFI 304 running like a barge under full throttle
    Bought a VS Stato yesterday, and it doesn't run to flash. First time we started it she didn't seem to fire all cylinders for a few seconds, so had trouble starting, idling sounds maybe a bit rough, either that or it's cammed, but I dunno the history of the motor. General driving is ok and when ya accelerate slowly it builds up speed ok, but if ya mash the pedal is coughs, farts and dies, unless ya catch it straight away and take a foot off the go pedal and let it go back to a idle, then slowly put ur foot down again.
    Anyone know where to start? When I get me VT off defect I'll spend a few bucks on the Stato, figured I might start with new plugs, leads, dizzy cap and rotor button and go from there.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    DANNY8's Avatar
    Apr 2004
    D22 St-r Navara
    Dec 2010
    perth
    VH SS
    May 2009
    Toowoomba, Qld
    no it doesn't use an AFM, it uses a MAP sensor instead
    are there any mods ? Factory memcal/chip ?
    is the check engine light flashing ? If so, check for codes
    I'd also suggest checking the MAP sensor hose that runs from the MAP, through the centre of the manifold and attaches at the front of the manifold just behind the throttle body neck (you may need to remove the throttle body to see it). Very common for the hose to kink where it plugs into the manifold as it is a 90 degree bend. It will cause all kinds of problems if the hose is restricted/blocked.
    Easiest way to check is to remove the hose from the MAP sensor end and blow through it. If you can't blow through the hose easily, then it's blocked.
    DANNY8's Avatar
    Apr 2004
    Ah ok, blew in the hose and it seems fine. Wouldn't have a clue if it has any mods. Didn't notice any engine light flashing....but the ABS doesn't work so I guess that light should be flashing too, but isn't, so maybe a few globes are missing.
    How do I check the codes?
    ari666's Avatar
    1966 impala
    Mar 2009
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    if it was a series 3 vs statesman with a roller 5ltr it would have had an AFM.
    But ima gonna go with rotr button dissy cap aswell.
    Check your error codes and bulbs in cluster cluster is easy to remove so it wouldnt take long. Does the oil light work?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    lift the fuel rails with injectors still in them and prime the system with the key a few times and look for wet injector tips we i just had one with 6 leaking injectors started horrible ran shit and had no power new set of injectors and shes an animal now and starts faster than you can let the key go
    1992 VQII Statesman
    Sep 2008
    do some investigation- ecu diagnosis, compression test, check for vaccum leaks and so on- could be losing a cylinder- check for blowback, injector not firing- if its been cammed perhaps not run in properly- faulty lifter- faulty rocker gear
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
  1. how to get full throttle with shift kit
    By baza in forum V6 Development And Modification
    Last Post: 07-03-2008, 07:26 AM
  2. 1/3 throttle is faster than full
    By VSIIBerlinaL67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 09:12 AM
  3. Now my car is running like a barge
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-11-2006, 03:05 PM
  4. 0-100 full throttle after dynotune
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2005, 12:24 AM
  5. WTB: VL turbo. full car, engine, running gear.
    By Jason1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 19-07-2005, 11:56 PM
