Results 1 to 4 of 4
Thread: GM Replacement Engines
    VS SS
    Aug 2010
    ACT
    Default GM Replacement Engines
    Hey all
    In my day dreaming I was thinking about stroking the 5L but I remembered that when I got it registered the mech who did the inspection said I had a different engine number to what the vin had. So I looked it up and the engine I have is a SU while the standard vs block was VU.
    Now my question is if the standard vs block (VU) could take the stroker crank without the machining would the replacement (SU) be able to as well? Bare in mind that the list states that there isn't any difference between model it just says vn to vs series 3 for both.
    I'll also put a shameless plug for the thread I started in vr-vs that should have been here about my lifter problem.
    5L lifter noise/Oil issue
    cheers
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    VS SS
    Aug 2010
    ACT
    1992 VQII Statesman
    Sep 2008
    if the engine was made during VS 1995 on it'd be the same
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
  1. Vn Vp Vr Vs Vt 5L engines
    By stumps5L in forum V8 Development and Modification
    Last Post: 23-04-2012, 01:09 AM
  2. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  3. DI Engines
    By Super Coach in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-08-2009, 08:54 PM
  4. vp engines
    By LESK1946 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 01:17 PM
  5. VN-VP engines
    By ***In The Build*** in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 08:29 PM
