Results 1 to 6 of 6
Thread: vs v8 ticking noise... + more... help
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    Default vs v8 ticking noise... + more... help
    hi guys , as title says i have a ticking noise coming from top of my motor
    a bit unsure what it could be? ive put a screwdriver on the vally inlet , rocker covers , and to me it sounds like injectrors , ive had them cleaned and still the same.. injectors have a slight scratch[ rrr] noise if i only move peddal a little bit.
    2. also every now and then car will feel like its starving for petrol, splutters ,only for a second ,ill put my foot down and it fixes it for then.. have changed fuel filter, and the bloke that cleand injectors checkt the fuel and was fine ie. no dirt or stuff in it.?
    3. white gunk stuff in my radiator , only a little bit. is that my vally inlet gasget ?
    cheers for your input>
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    it sounds like your fuel pump is on the way out, mine used to splutter n sometimes stall when the pump was almost stuffed, if your vally inlet has gone your oil should be white n gunky, also the tapping could be lifters, how many kms has it done?
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    white gunk in your radiator would suggest a blown head gasket mate. Not a cheap fix.
    don't take this wrong or anything but ARE YOU ####ED IN THE HEAD????
    Reaper
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    she has done 233,000 ks, got no white gunk in my oil just in the radiator, spewn if its a head gasket, the tapping seems to be comin from injectors? or under injectors...
    and yeah the fuel pump is original i think so that is possibly the problem there.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Does the ticking noise go away when you rev it? And more of a ticking noise when its cold? If so firstly check the oil levels, and obviously make sure it isn't milky, but by the sounds of it one of your lifters i sticking. I have this on my ute too.
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    no the ticking stays there high revs and on idle {can hear quite loud when idling} and no milky gunk in the oil only in the radiator..
  1. Ticking noise
    By Dee jay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2011, 12:03 PM
  2. Ticking Noise
    By INDACLUB in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2011, 01:58 AM
  3. RE: ticking noise
    By Boomshanker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2010, 06:52 PM
  4. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
  5. ticking noise..
    By matt_gotigers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2007, 09:44 PM
