Results 1 to 20 of 20
Thread: LS1 Throttle Body on 304
    VK Berlina 5L Project
    Feb 2011
    Ballarat
    Default LS1 Throttle Body on 304
    Hi guys,
    I heard you can fit an LS1 throttle body onto a 304. Is this a fairly straight forward swap? Will I need the LS1 MAF meter to go with it?
    Thanks!
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    It is not a "bolt on" job.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Feb 2011
    Ballarat
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The throttle body mounting stud arrangement is totally different between the two. Also the 5litre tb has 2 studs whereas the ls1 has 4. You're going to need to make up an adaptor plate that suits the ls1 tb mating face on one side, and the 5litre manifold on the other. This adaptor plate would also have to be internally tapered to suit the bore size of tb down to the inlet manifold, otherwise your inlet air charge will be like hitting a wall ubstruction. Better though would be to enlarge and port manifold to suit but this would require its removal. You may also need to customise the throttle cable holder and linkage on the ls1 tb.
    No you wont need to use the ls1 maf sensor. You can, but its not necessary. This is because any increase in inlet air charge flow you may gain will still be within the scale of the stock 5litre maf.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by cander24 View Post
    LS1 is 3 bolt
    LS2onwards 4 bolt
    See Mace about there 70mm throttle for V8
    Feb 2011
    Ballarat
    Thanks for the help. I was just told it was possible to run then but didn't realise how much work is involved. Would the gains be worth the effort of making it fit?
    Grennan's Avatar
    Grennan is online now Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Quote Originally Posted by GunnVK View Post
    Youre better off looking for a ported 304 TB if you are looking at changing it. However, gains are usually pretty small. You are going to be bottle necked somewhere, changing the TB moves the bottleneck down the line. I know on the LS1 changing the TB is usually a waste unless you change the manifold because that diameter remains the same. Im not sure how it works on the 304, but I would imagine its very similar.
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    1992 VQII Statesman
    Sep 2008
    It may make some difference but due to the low 500cfm ish nature of the stock manifold it won't do much. Even with the Mace throttle body kits out there and their reconfigured stock manifold they're not worth it either. A Harrop dual plane with a decent 1000cfm throttle body on should do fine- bit more stuffing around but
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
    Feb 2011
    Ballarat
    Ok thanks for the help and info! I might just give the stock one a tidy up till I can get enough $$$ for a decent one.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by Grennan View Post
    ^^^^^ that. Changing the TB on a holden 5 litre is a waste of money unless you do the manifold to suit. If you want to do that you really need more compression/revs and a engine rebuild would be in order.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by VQ-Assault View Post
    The intake manifold only flows as much as the throttlebody. Peter starr found this out when develping the starr manifold....the standard 65mm throttle flows 550cfm but when replaced with a 90mm it flowed 1200cfm
    Abraisive flow engineering in sydney can make your intake flow better with the standard throttle
    and even flows better with a larger one
    Taken from another forum
    STOCK V8 HOLDEN EFI INTAKE MANIFOLD.
    Flow Tested with stock 65mmT/Body bolted on & wide open.
    Runner no.
    1.--------211.3
    2.--------213.8
    3.--------209.3
    4.--------203.8
    5.--------205.3
    6.--------202.7
    7.--------201.9
    8.--------206.2
    STARR CONVERTED HOLDEN INTAKE MANIFOLD had been PORT MATCHED
    Flow Tested with Starr 90mm T/Body bolted on & wide open.
    Runner no.
    1.--------237.8
    2.--------231.3
    3.--------233.1
    4.--------236.4
    5.--------234.8
    6.--------230.1
    7.--------235.3
    8.--------231.8
    OUR EXTRUDE HONED STOCK HOLDEN INTAKE MANFOLD has been PORT MATCHED
    Flow Tested with the stock 65mm T/Body bolted on & wide open.
    These numbers would be higher with a 68mm or 70mm T/Body upgrade, we did not have any other upgraded T/Bs at time of testing.
    Runner no.
    1.--------248.6
    2.--------245.9
    3.--------245.7
    4.--------247.3
    5.--------240.1
    6.--------249.3
    7.--------246.7
    8.--------249.8
    This is the above same intake manifold but a Starr 90mm neck & T/Body has been tig welded on.
    Flow tested exactly the same way as the above manifolds.
    Runner no.
    1.--------268.3
    2.--------266.9
    3.--------266.8
    4.--------272.1
    5.--------269.2
    6.--------270.8
    7.--------266.3
    8.--------268.7
    Surprising what you can get out of a bunch of bananas.
    Feb 2011
    Ballarat
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    There is some gain to be had by bolting on a larger TB but the neck on the manifold is about 68mm to putting on a TB larger then that is a waste of time unless you modify the manifold first. No point putting on anything more then a 70mm TB.
    considering the price of the star manifold money can be spent more wisely
    cheers
    Body by Holden, Soul by Brock
    the Legend will live forever
  15. #15
    Mar 2008
    The throat (neck) diameter of the EFI 5L manifolds we have here vary between 69-69.5mm
    For people who are considering porting their EFI 5L manifolds and are planning on getting a custom tune done, we'll have in stock LS1 throttle body adapters to suit. The price for the adapter kit will be around the $130 mark. All that will be needed in addition to the kit will be a modded throttle linkage or LS1 throttle a cable.
    It's no Group A setup, but then again some people options, who can't afford one for arguments sake
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  16. #16
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    steve,
    For the OP's sake do you know how much the intake neck can be ported?
    ie. can it be matched at 75mm same size as the LS1 throttle?
  17. #17
    Mar 2008
    Quote Originally Posted by Munz View Post
    steve,
    Good question. I dare say to get the neck of the manifold ported and the runner match ported/cleaned up would be around the $300-$400 mark give or take. You would be able to port the neck out 75mm to suit a stand bored out LS1 throttle body. I say bored out as the minimum throat diameter on a LS1 throttle body is 72mm (the butterfly though is 75mm)
    MaceEngineering
  18. #18
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    Default Extrude hone bunch'o'bananas manifold flow data: Interesting...
    Awesome info. I wasn't aware that the extrude hone process could be as effective. If the flow data figures are correct then I am keen to give this a go myself.
    I'd rather have the low profile manifold than the TB/Air-filter assembly peeking through the bonnet and attracting the wrong attention. The missus prefers the way it "used to look" over the bonnet without the engine inspection hole that was cut and so I reinstalled the stock manifold setup and the stockie bonnet.
    I'd really like to know if there is a sure way to insulate the heat transfer from the block to the inlet manifold. I've had to place a towel over the bunch'o'bananas to keep myself from getting 2nd degree burns when working on the engine and it seems to take bluddy ages for the manifold to cool down when it is parked (the local feline vagrants use that as a heater blanket a night. Argghh!).
    I apologise for the additional comments regarding heat transfer if this has been addressed elsewhere and is not considered as part of this thread. Cheers all!
  19. #19
    Reaper's Avatar
    Aug 2004
    ............nm
    Reaper
    Reapers Black VP SS
  20. #20
    VE SV6 ute
    Apr 2009
    vic
    don't bother with V8's, get a V12 TT
  1. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  2. [WA] WTB VS V6 Throttle body
    By Pav in forum Swap / Wanted to Buy / Trade
    Last Post: 07-10-2009, 11:29 PM
  3. Throttle Body
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-03-2009, 08:24 PM
  4. VK throttle body
    By stroke it in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2007, 07:52 PM
  5. throttle body help plz.....
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-03-2007, 09:30 PM
