Results 1 to 25 of 25
Like Tree4Likes
  • 2 Post By ari666
  • 2 Post By ari666
Thread: blowen 253?
    VK ROYALE
    Sep 2009
    Default blowen 253?
    ive got my hands on a 3/71 blower with 4 barrel adapter and all the pulleys, would this suit my 253 with 308 heads or would i destroy the motor? ive heard the crank could snap easily? would i be able to just bolt it on or to much money and work involved? cheers
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    lol. well.... give it a go.
    stocK 253? what year? obviously not your vk cos they didnt come out in vk's. the length of the snout correct for your intake? whats your CR? what cam? etc etc
    etc
    etc
    etc
    etc
    etetetetetetctctctetctect
    XR6T, sorry
    Nov 2010
    Carrum Downs
    I've turbo'ed stock 253 and 308 engine no worries, stay sensible and good tuning, retension the cylinder heads before you start.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    3x71 = 213ci smaller than your motor capacity but it still might work if you overdrive the #### out of it
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VK ROYALE
    Sep 2009
    it was running on a 350chev, not sure if its overdriven or under is there a way to tell?
    it cost me 500 all up was just thinking of doing it for a bit of fun but dont wana go blowing my crank or anything
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    You'd be doing well to snap a crank, I'd imagine something else would give first.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by EFFDUP View Post
    why? cos' 253 cranks are so damn expensive?
    lol, just stick it on. if you blow it up, save 5 dollars and get a new 253
    VK ROYALE
    Sep 2009
    what other damage can i do? does the carb need to be anything special or can i use my 600 holley?
    XR6T, sorry
    Nov 2010
    Carrum Downs
    Nuthin if you draw through, you will need to manage the ignition timing, boost retard.
    Joel
    VK ROYALE
    Sep 2009
    so its not just a matter of bolting the blower on tomorrow and way u go is it
    ari666's Avatar
    1966 impala
    Mar 2009
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    VK ROYALE
    Sep 2009
    just tried fitting it all up, gona take alot of work to make it fit, the blower needs to come forward about 2inches, might just flick it off, i also have power steering which wont work there will be no room. BUGGER
    ari666's Avatar
    1966 impala
    Mar 2009
  15. #15
    XR6T, sorry
    Nov 2010
    Carrum Downs
    On a Buget, weld up the mechanical advance, start around 15 degrees static (also total) and fit the blower.
    Joel
  16. #16
    VK ROYALE
    Sep 2009
    have been offered a swap for a tunnel ram setup for 308, is this worth a straight swap?
  17. #17
    VK ROYALE
    Sep 2009
    3/71 blower with 350chev manifold and all the pulleys FOR a cain tunnel ram with 2 450 holleys
    does this sound like a resonable swap? or should i hold on to my blower?
  18. #18
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I'd go the tunnel ram...that's just me tho. Rekon those manifolds go for about $1000-$1500, sometimes can find them cheaper if ur lucky.
  19. #19
    ari666's Avatar
    1966 impala
    Mar 2009
  20. #20
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    I'd mabye swap the blower set up for a DECENT manifold and carb (if the blower definately won't fit that is), unfortunately, a tunnel ram isn't a decent manifold (for a street car). If you're going to have a hole in your bonnet, make it for a blower.
  21. #21
    VK ROYALE
    Sep 2009
    i am still trying to have a crack at fitting this blower, the crank pulley is not gona fit at all could i use a gilmer drive pulley on the crank or are they completley differant?
  22. #22
    ari666's Avatar
    1966 impala
    Mar 2009
  23. #23
    VK ROYALE
    Sep 2009
    i can make a spacer for the snout thats ok, just the pulley for the crank isnt gona fit (its off a chev) was thinking of just using a gilmer pulley on the crank
  24. #24
    ari666's Avatar
    1966 impala
    Mar 2009
    ??? is it a V-pully, serpentine? i dont understand. swapping the pulley would be easy. gilmers are commonly used, but i dunno where you would get one that length though. itd have to do the crank, alternator and PWR steering. itd have to be huge. maybe look into a later model serpentine belt?
  25. #25
    VK ROYALE
    Sep 2009
    i can use the gilmer power steer part for the alt,crank,water pump just wondering if i can use the bigger part as my blower pulley on the crank?
    does anybody know the size of the gilmer pulley thanks
  1. Blowen HeadGasket I think
    By darktele in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2005, 01:50 PM
