View Poll Results: mafless tune good or bad for a street car
Voters
2. You may not vote on this poll
  • good
    2 100.00%
  • bad
    0 0%
Results 1 to 2 of 2
Thread: mafless tune pros and cons
    commodore vt ex
    May 2010
    Default mafless tune pros and cons
    i have bin tossing up the idea for a while now wither or not to get a mafless tune on my vz ss 5.7lt,
    please note that i have got a 3" stainless 4 in 1 exhaust with pacemaker extractors, and high flow cats
    so if someone could state the pros and cons of getting a mafless tune, eg fuel efficacy, engine smoothness in low range revs, and so on
    any help would be appreciated
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    In a VZ you can go mafless or keep the maf - no real diffference as the maf is no restriction, unlike pre-VZ. Also, the maf tune retains a little bit more security if you get bad fuel, or bad atmospherics between seasons, as the maf meters the airflow, whereas a mafless tune is built entirely from the VE map. A mafless tune is a little bit more responsive to throttle inputs, but the difference is almost negligible.
    In your application - bolt-on only - a maf tune would be 99% of mafless, so no real biggie.
    As for a tune in general - it will provide more torque / power, better fuel economy and an auto transmission can be set up to shift better.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
  1. Oil catch can pros/cons???
    By Heeey!! in forum V8 Development and Modification
    Last Post: 23-09-2010, 05:58 PM
  2. pros and cons
    By SAV_117 in forum The Pub
    Last Post: 29-08-2009, 09:12 PM
  3. Super 6 Pros and Cons
    By King_berald in forum V6 Development And Modification
    Last Post: 06-05-2009, 11:19 PM
  4. LPG - Pros V Cons
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2008, 01:56 PM
  5. Pros And Cons Of A Shift Kit
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 11:22 PM
Tags for this Thread
