G'day guys, rookie questions here, I've started getting the bits for the 304/355 I'll build soon not 100% on what yet. I managed to get the manifold and an efi hardware throttle body second hand on the cheap (manifold isn't here yet though), problem is I don't know how to set it all up, the throttle has the TPS and IAC (whatever it is) sockets already, but I have no idea where or what type to buy for the accelerator cable/bracket.
I'm guessing from the few pictures that I'll need a breather setup for the rocker covers. But what do I do with the vacuum lines(two coming off the side of the current throttle going to canister next to radiator).
As for the fuel rail, will I need a new housing or will the one off my bananas fit under the fuel rail, and what do I get to mount the rail to the manifold at the proper injector height. And if possible can someone point out which sensor/goes where, I'm assuming that the sensors will be pretty simple in the way that they'll only fit in their individual holes.
I think that's all, if anyone knows anything else I may need or problems I'll run into, or say different hoses for the heater that run neatly across manifold etc. just shout out.
Lastly, is it worth whacking it all on and getting a foam tune in the meantime until I get motivated to make a final choice on the engine.
