Results 1 to 4 of 4
Thread: Spark plug choice?
    VP SS and VL Turbo BT1
    Oct 2009
    Young, NSW
    Default Spark plug choice?
    Ok om after a hotter spark plug for my 5 litre. I got no clue what to look for?? Anyone know the parts number for them and brands?
    Cheers.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Go here; http://www.ngk.com.au/sparkplug_vehicle_type.php
    Input your vehicle details and then find out the Standard Recommended Plug Number.
    Once found, go and check out what the plug code means here (click on "part numbering system"); NGK Spark Plugs Australia
    Once you have done that, you then need to change your plug code by one number to either a colder or hotter heat range.
    I used to run 1 heat range colder on my 10sec street driven VL Turbo 3ltr. For example, standard NGK plug is BCPR6ES and I ran BCPR7ES. I did this due to higher and hotter combustion chamber temperatures in my boosted car.
    Hope that info helps
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    5 is for petrol 6 is for gas or stupidly high comp ratios. think the 304's are 1.0mm gap stock and 308 are 1.5mm
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Standard petrol spark plug numbers are as follows:
    308: BP5FS (HQ - HZ)
    308: BPR5FS-15 (VB - VL)
    304: BPR6EF (VN - VT)
    Now, you say you want a "hotter" plug.
    Do you want:
    1) a plug that runs hotter? i.e. one with less ceramic
    2) a plug for an engine that runs hotter? i.e. a colder plug, with more ceramic to protect the electrode
    IF you want a cooler plug, and the engine is a 304 in your VN, then you want BR7EF
    The 1972 HQ Kingswood
  1. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  2. Compression influence on plug choice?
    By Dan355 in forum General Discussion
    Last Post: 24-11-2006, 09:55 AM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. Best choice of spark plug VT 5L
    By RR5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 09:29 AM
