Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Blown V6 Hatch
Thread: Grouting a block?
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default Grouting a block?
    Yeah I was wondering what "grouting " a block actually does.
    I was reading a discription on eBay about an engine where it requires the engine to be grouted in order to see the predicted HP?
    Being in construction and hearing the word "grout" being used in a mechanical aplication is somewhat confusing.
    Can anyone tell me what it is and how its done and the pros and cons that go with it?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It is filling the water jackets with grout making the block more solid to strengthen it. It is used mainly in drag engines that do short runs so cooling isn't necessary.
    Visit my Facebook page
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    It's used for a couple of reasons in Holden V8's. First reason is generally on 383 stroker Holdens, to gain enough clearance for the longer throw of the 383 crank you normally go through the water galleries in the side of the block (or go very thin in material) so the block is grout filled up to the welch plugs to fill in the void in the block. 355 strokers don't require this to be done as there is not as much metal to be removed.
    The second reason is that it greatly increases block rigidity (this is with any engine, not just Holden V8's) obviously making the block much stronger and helps to stop the block from twisting and/or the main caps walking.
    The pro is obviously making the block stronger. The con is that it obviously means less coolant in the cooling system, which can lead to heating problems. However, given that a lot of the cooling is done in the heads, it normally doesn't present a problem, but the chance of heating problems is always there.
    You can fill a road engine with grout to the welch plugs, but on an out and out race engine that has no cooling system, normally the whole engine is grout filled to make the block as strong as possible.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Ah ok, yeah cheers for the reply.
    Makes allot of sence now I understand the#principle of it.
  1. Short block ...... Big block?
    By vtv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2011, 07:23 PM
  2. Block
    By damankerrison09 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-04-2010, 02:45 PM
  3. [SA] VL BLOCK & Cam
    By damankerrison09 in forum Parts And Other Items For Sale
    Last Post: 07-04-2010, 05:25 AM
  4. 402 big block
    By seb402 in forum General
    Last Post: 21-01-2010, 09:59 AM
  5. New (68y.o.) kid on the block.
    By alex120 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2006, 08:24 AM
