Results 1 to 12 of 12
Thread: roller cam conversion
    micsnaffled's Avatar
    micsnaffled is offline micsnaffled
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Default roller cam conversion
    Got a vs ss with standard hydrolic flat tappet cam and lifters in a v8, want to convert to a roller can setup. Anyone know what's needed??
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    To fit to a non roller block need link bar type roller lifters plus roller camshaft
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    I'm trying to sort out a brand that is going to fit my car, vr ss.
    Do I need a cradle, like in the vs vt??
    Most roller lifters have this cross bar between them but some are for chev some are splayed??? Need a couple of brands that can suit my car!
    Something about a billet cam gear as well yeh?? Any reason why I should go roller as a pose to flat tappet??
    Cheers all!!
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    roller cams also have a great performance advantage over the flat tappet. The faster you can get the intake valve to maximum lift, the longer it can stay there before the piston comes rushing back up the cylinder to compress the air fuel mixture. If the goal is to load the cylinder with as much air and fuel as possible, the longer you are at maximum lift the better. Flat tappets require a smoother transition from the base circle of the cam to max lift, leaving less time for the lifter to dwell there. Roller lifters, on the other hand, can survive a much more abrupt transition resulting in extra time at max lift. If you compare a roller cam lobe to a flat tappet lobe, you can see the roller cam has a larger radius at its peak, holding the lifter at max lift for a longer duration.
    http://www.lunatipower.com/Tech/Cams...tOrRoller.aspx
    ask steve @ MACE for advice (site sponser) as he does cam packages for the 304 5L
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Awesome cheers!!!
    Speaking to mace about a throttle body, so I'll hit him up with the cam selection while I'm at it!!!
    Cheers!!
    Rebuilding the engine today!!
    Not ready for 2 weeks
    Can't wait!!!
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i've heard the lifter bores might need to be sleeved as well
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Why the need??
    Aren't they suited to the block??
    Are the smaller width wise than a hydrolic lifter??
    What about height size??
    I'll investigate further, Friday is the day he's calling about head flow rates, the condition of all parts( most of them will be discarded) and what roller lifters and cam we will use, I'll hit him up then, cheers!!
    I've posted another... whatever and it's about my rebuild. Having problems with manifold choice, selection is proving to be hard, this intern will stuff up cam choice and head work!!
    Time is running out, as the car was handed over today! Bugger
    VS 5L M5 VS 6L M6
    Apr 2009
    dunno thats just what ive heard..
    on the subject of manifolds, a mate has a vk 355 with a vt roller block, hyd roller cam, and a harrop dual plane manifold with an 830cfm (i think) barry grant carby on it. it works well, responsive as anything and all fits under the bonnet. he's real happy with it
    Avoid cluey police
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Being in a vk, he can run it carby style while having a roller cam. I'm efi and can't do that!
    I've found my roller cam setup now for my vr v8 build
    Cheers all
    VS 5L M5 VS 6L M6
    Apr 2009
    u could if u got a 4 barrel throttlebody (looks like a carby). i'm pretty sure the harrop and torque power manifolds have injector bosses cast into them so u can get some injectors and fuel rails on there
    Avoid cluey police
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    I've had heaps of problems with the EPA. I would love to go throttle carby style but if I was to get pulled over, (like I have in the past and had to change my manifold back to a standard one) it would kill me!! What then??? Go back to standard, new tune... $$$$ for nothing!!
    Going to be a come or motec manifold
    Ready for a turbo (hidden)!!
    Cheers!!!
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Harrop torque all those high rise manifolds need a hole in the bonnet even without a spacer. Come do a dual plain high rise with a 1" spacer fits all under the bonnet.
    Still EPA is a problem, all the brake booster hoses I think need to be plumbed in, all sensors. $$$$
    Hot air is another one. No holes!!
  1. [VIC] Wtb or swap: 1.7 roller rockers for my 1.8 roller rockers for ls1
    By grantlyy in forum Swap / Wanted to Buy / Trade
    Last Post: 20-07-2011, 04:07 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. [VIC] WTB- vs ute roller lid
    By schwimmer in forum Swap / Wanted to Buy / Trade
    Last Post: 15-03-2010, 08:26 PM
  5. Roller Rockers LS1
    By minux in forum Yella Terra
    Last Post: 26-03-2007, 06:02 PM
