Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By Morton
  • 1 Post By calais24/7
  • 1 Post By strgas
Thread: vs 5L siezed, confused
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Default vs 5L siezed, confused
    Alright so here goes, im so fkn pissed off right now, ive had the worst luck, anyways i wont bore you with my life story. I was driving along in 4th (manualised b&m shifter) and my car all off a sudden started to free rev(as if it was in neutral) and i tried all other gears but nothing. So i pulled over and turned it off, put it in park, started it again, and nothing, just free reving. Turned it off and went to start it again but it just goes clunk. And i put a socket on the engine tried to turn it and you cant even manualy crank it. WTF would it be, would it be siezed? if it was seized how did it start and rev? no lights came on the dash, no noises. So im stumped, what could it be? Pulled the inspection cover off the gearbox and everything looks good.??
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    calais24/7's Avatar
    Jul 2009
    strgas's Avatar
    Oct 2009
    well either a seized engine or trans have fun removing the bolts from the flex plate without a turning engine is a bugger next option is to remove engine with torque convertor attached or remove both engine and box as one then separate later, makes a hell of a mess and if the motor is seized and gas axe will remove the plate nicely
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    You wouldnt have seized your engine, so that's a relief, id say something in the tranny has let go.
    Get under the car tomorrow and drop the Trans fluid and look for metal shaving ect. If you see shards then pull the tranny out and then give it a kick in the guts, you'll find it WILL turn over.
    A box from ebay or the wreckers should be under $200, but like mentioned above the flex plate could of sheared off and their only about $50
    Good luck
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    It sounds like transmission man. Or torque converter.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Torque convetor bolts come out? that would make a horrible noise youd think though.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by VK SL 3800 View Post
    i was just about to ask: did it make a blood-curdling noise when it let go? I can easily see how a manualised auto could lead to a dismantled flex plate
    I'm also going to hazard a guess that if your flex plate has been damaged, your starter motor is going to have a hard time engaging it to turn the engine over.
    Oh, and you being unable to turn the engine over by hand is probably just a little thing called compression. Take out all your spark plugs, get a longer breaker bar (750mm or longer) and try again. It'll turn over
    The 1972 HQ Kingswood
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by 304runner View Post
    Good luck
    THIS made my morning, i was so pissed thinking it was siezed, and it was starting to sink in that id be forking out 1k + for a new engine, as for the noise it made, it was wierd, you could tell something went, kind of like a clutch was slipping and spinning but obviously this is auto. Either way looks like the box will have to come out
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by Morton View Post
    Yeah i know i wouldnt be able to start it like that but should get it to turn over if that makes sense? When i turned the key i had someone watching and they said it was jamming and bouncing back, ( i forget what they said was bouncing back though lol)
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    calais24/7's Avatar
    Jul 2009
    nope, no unusual noises, no warning lights, nothing. How can i get the flex plate off without turning the engine? lol im not looking forward to any of this shit
    strgas's Avatar
    Oct 2009
    If you cant turn the engine due to being seized then you will have to cut the flex plate off away from the convertor then unbolt the plate from the crank.
    Last time i did this job was after a owner of vp clubsport decide to top up his own oil late one night , later that night his engine seized next day he checked his oil in the shed and found he had put 1/2 litre of round up weed killer in his sump , not good for a car with less than 300 kms on the clock
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you tried putting it in neutral to turn it? i know i know its auto, but if its locked then it defys all reason anyway, also jack the rear tyres up off the ground?
    such a weird problem. can you push the car? have you tried turning the balancer anti clockwise?
  15. #15
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I would pull the starter off and see what you can see, if its got an inspection plate pull that off and have a look up the gap, have you tried winding it anti-clockwise yet?
  16. #16
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by strgas View Post
    hahah spewing! im not looking forward to it thats for sure
    Quote Originally Posted by ari666 View Post
    Nah i havent tried starting it in neautral, i will do that, yess it was able to be pushed, pushed it further off the road, then winched onto the tow truck. and ill try turn it over with the wheels off the ground.
    and ill try turn the harmonic balancer the other way
  17. #17
    calais24/7's Avatar
    Jul 2009
    Well we might be looking at it tommorow, its been sitting under a cover with like 2mm of dust lol. But hopefully we will find the cause tommorrow, and ill have this page open and trying everything. kinda accepted the gearbox is going to have to come out and we are planning on doing that. i just hope it will turn over and its only the gearbox
  1. Siezed VSII Commodore Ute
    By basebrendan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2011, 07:41 AM
  2. Rear wheel siezed onto hub
    By stew_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2010, 03:45 PM
  3. siezed motor
    By VL Berlina 5speed in forum General
    Last Post: 22-08-2009, 10:31 AM
  4. clutch fan nearly siezed
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2007, 10:06 PM
  5. Siezed by Customs
    By VH SLE in forum The Pub
    Last Post: 21-04-2006, 09:31 AM
