Results 1 to 4 of 4
Thread: roller rockers
    vn ex cop V8
    Nov 2009
    burnie tas
    Default roller rockers
    i've just brought a set of crane cam roller rockers adjustable that bolt right on to standard head
    my cam is a crow cams 4761 hydraulic cam and lifters whats best way to set them up engine is a 355 stoker 040tho
    Evoke VE HSV GTS 6.0 auto, XR6 turbo ute.
    Aug 2011
    Mount Gambier, SA
    Mate, looking at doing this to VT Clubby, what did you pay for them, and are they a direct fit to the standard heads?
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    have a look at this mate there is a video of a comp cams representative installing adjustable roller rockers... pretty sure they'll be the same
    If in doubt......FLOOR IT!!!
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    when you say "bolt straight onto the head" you mean shaft mount? do the intake and exhaust have a bar joining them?
    if not adjusting is easy. if you are doing the intake valve, rotate the engine until the exhaust valve starts to close, then graba poushrod and rotate it back and forth with yoiur fingertips. tighten the adjuster till it just grabs the rod, then stop. do that to all of the vlaves then start the engine with the rocker cover off. let her warm up to operating temp then tighten each one to the point where it just stops tapping and you are done.
  1. [VIC] Wtb or swap: 1.7 roller rockers for my 1.8 roller rockers for ls1
    By grantlyy in forum Swap / Wanted to Buy / Trade
    Last Post: 20-07-2011, 04:07 PM
  2. Has anyone got 1.9:1 roller rockers on ls1
    By Mickyshazz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-11-2010, 06:58 PM
  3. Roller Rockers
    By VX SS 340 HP in forum Yella Terra
    Last Post: 31-10-2010, 03:41 PM
  4. roller rockers
    By shane01991 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2010, 01:48 PM
  5. 202 Roller Rockers
    By jakbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2009, 08:05 AM
