Hi, i have a 304 motor in my VS and was just about to purchase a 70mm throttle body for it but have noticed a bit of a trend with people fitting a 90mm throttle body.
Can anyone tell me if there is a positive side to doing this and if so what is the 90mm throttle body from?
Also are there any other options as far as a new throttle body goes other than the standard one bored out to 69-70mm.
I see alot of billet "universal" 70-90mm throttle bodies etc but really have no idea.
Its been covered a heap of times.... Some say yes it makes a difference and some say no...
Click here >>>> LS1 Throttle Body on 304
Thanks for the read![]()
The restriction is in the manifold itself. A 90mm throttle body is pointless on a standard manifold.
Cheap, fast, reliable.....you only get to choose two.
I figured as much but couldnt see why people were still doing it on standard 304's
Ill stick with the 70mm one from mace engineering.
Because they are wankers lol
little bit of a dig but is the mace 70mm throttle body worth it on a 355 stroker running the standard manifold or is the standard 65mm throttle body sufficient? thinking about the 70mm for my VS Senator
My Senator 355 Stroker
http://forums.justcommodores.com.au/...5-stroker.html
The 70mm is better but you also need to port the runners on the standard manifold and match the intake neck to the new 70mm T-body. The 90mm is only good for 350ci and above or heavily worked 5L engines and even then you need the Starr manifold to match upto the difference. Im getting the 70mm at the moment with a ported standard manifold and a tune. My mate has that combo and it works well. A bit of handy work inbolved but its worth it and you can save yourself a lot of coin.
Apparently hey do. I was just discussing it with someone who just bought one. They are on exchange basis of your stock manifold. They cut the manifold into sections, port the runners out and raise the height as well as the modifications you just mentioned. His is significantly higher too. Unless of course his was a special order from Starr Performance Victoria.
