Results 1 to 5 of 5
Thread: Torker vs standard manifold
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    Default Torker vs standard manifold
    Hi all,
    Ive got a mild 308 in my VK.Flat top pistons 30 thou over,mild cam,pacemaker headers into 2.5 mandrel exhaust joining to one three inch before diff and a holley 600.Am vurrently running standard red heads and a torker manifold.Its currently making 132 kw and 677 nm torque.
    Next week i will be putting on big valve black heads that have been ported and polished.The heads also came with a standard four barrel manifold that has also had a bit of grinding work done to it.
    Am i better off with the torker or the holden manifold??
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Standard manifold would probably choke up the heads but will most likely perform well 1000-4000rpm range, where the torker will perform better in the 3000-6000 range and be able to supply the heads with more air/fuel where it needs it most
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    considering the rest of the engine spec's the factory ported manifold will be a better match then the torker manifold. the torker manifold has very short runners and is designed for a rev happy engine.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VX L67 S
    Oct 2011
    The Brock manifold is the go op if you can get one otherwise the performer is the next obvious option.
    The torker is too big for your application as mentioned above also
    My matchported Performer was good for 115mph from 207rwkw in a full weight 308(cc272 cam,4200stall,4.11's)VH sl/e.
    Mar 2009
    Coromandel, NZ
    Sweet as,How do you tell a brock manifold from a standard one?
  1. Manifold on standard 304
    By LT2009 in forum V8 Development and Modification
    Last Post: 28-11-2011, 06:30 AM
  2. [SA] FS: 350 Holley, Redline Torker 2 Manifold (9/12 port), NOS Dry nitrous kit
    By Dan355 in forum Parts And Other Items For Sale
    Last Post: 21-03-2011, 10:21 PM
  3. [SA] 350 Holley, Redline Torker 2 Manifold, Nitrous Kit (Red/Blue 202)
    Last Post: 30-08-2010, 06:37 PM
  4. Modifying the standard inlet manifold
    By stocky in forum V8 Development and Modification
    Last Post: 09-01-2009, 11:19 PM
  5. brand new holley 750 and edelbrock torker manifold
    By kwik6 in forum Parts And Other Items For Sale
    Last Post: 19-02-2008, 06:28 PM
