Results 1 to 8 of 8
Thread: VS 5.0L fuel pressure
    VS 5.0L statesman
    Feb 2011
    Default VS 5.0L fuel pressure
    Does anyone know if running constant 3.0bar fuel pressure will destroy a standard fuel pump been through one pump and now symptoms of another after a month or two, bouncing fuel pressure and loosing pressure under high revs, also get hard bubbling in the tank after i switch the car off????
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Have you checked the actual fuel rail pressure?
    Factory reg runs @ 43psi (3 bar)
    get under the car and check the hard lines for damage, the feed line may be crimped causing excess pressure at the pump. When was the last time the fuel filter was changed?
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS 5.0L statesman
    Feb 2011
    Hi reading was taken from the AFPR about a foot away from the rail return at 45psi, drops to like 20 something when you give it a hard rev, and the fuel filter has had about 8 tanks through it maybe 3 months old, no signs of damage to hard lines that i can see. lost fuel pressure and died the other night and no pump, came out next day and bingo pump back, my engine combo gives me 90kpa on idle so that's why i went the AFPR Cheers
    VS 5.0L statesman
    Feb 2011
    VS 5.0L statesman
    Feb 2011
    Ok when for a drive again today and gave it a hit and pulled all the way than slowed down to take a turn a straightened up and car died pulled over and turned ignition off, turned back on fired right up done it a few times.
    Can some one tell if running constant pressure of 43psi will kill my pump
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    if ya motor is stock then run standard spec fuel pressure as noted above! if the pump cant maintain its pressure then its cactus-providing all the fuel lines and rail is faultless. change out the existing pump and compare the differences
    VS 5.0L statesman
    Feb 2011
    OK thanks, Not stock, Just another thought on why my pumps are going, If i have reduced the return flow to the tank (constant 3bar) than does that mean my swirl pot is not getting an good volume of fuel under a set level causing the things to die early
    VS 5.0L statesman
    Feb 2011
    OK now i'm not sure if its the pump or ignition it keeps dieing after a hard rev then starts right back up most of the time, but upon searching under the bonnet i touched my ignition module on the removable cap in the center and the ####er shocked me, could this indeed be the culprit to my problem..
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  3. VS fuel pressure
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2009, 09:59 PM
  4. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  5. Fuel Pressure Reg
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2007, 10:11 PM
