Results 1 to 5 of 5
Thread: removing heads
    Vl Calais Turbo, Vn Calais 5L
    Feb 2011
    Sydney-west
    Default removing heads
    I'm in the middle of hanging my self due to water pouring out the sump plug and i've decided to just bite the bullet and take the heads off.
    Now, i've heard that i'll need a tool to remove the springs/rods or something, because i could drop a rod? ? ? but i can''t quite grasp it....
    i understand the removal of intake manifold and exhaust, plus the alt and P/S brackets.
    anyone done it?
    It's just a 304 with mild cam, had roller rockers removed prior to me buying it if it makes a difference.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    To replace a head gasket (which im assuming you're attempting) is easy... You don't need to touch any of the valve springs or the collets, so just unbolt the head bolts and it should just come off. (with a bit of a wack with a rubber mallet but by rights they should of been placed on dry)
    When I removed my head I did take off the rockers, if you do this don't worrie about anything being lost in the engine because you should by rights be replacing the valley cover gasket too and with the valley cover off everything is easy to reach, the issue is making sure you place everything back in the same way it came out.
    Feb 2011
    Sydney-west
    Thanks for that, yes i'm just gonna replace the head gaskets and have the heads checked out for cracks and decked.
    i was thinking about changing the rockers if the funds permit, would i do those with the heads on or off?
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Make sure u clean ALL gasket surfaces so they don't have any shit on them, and make sure the shit u clean off them doesn't end up inside the motor!
    Don't put ur head gaskets on back to front, it's easily done so make sure u check them b4 dropping the heads back on.
    With the intake manifold gasket I use silicone (the blue stuff) around the outside of the water jackets. I just use a small smear then wipe it around the 4 of them, drop the gasket on, use some electrical tape or sumfin over the top corners to hold them in place, and put more silicone around the 4 holes again (opposite side of the gasket......or just put the silicone on the gasket b4 ya put it on). And instead of using the cork front and back gasket, lay a bead of silicone in place of the gasket, then drop the manifold on. Don't use too much silicone tho, ya don't want shitloads of excess pushing out when u bolt it all down coz you'll end up with alot inside ur motor which can break off and eventually clog up ur oil pickup, and yeah no oil is no good lol.
    Feb 2011
    Sydney-west
    Thanks for that info, i've just finshed doing the heads and that was very useful info. . . then guess what happened......
    filled it up with coolant and out the sump she pours once again...
    so off came the water pump and i see a couple of small looking possible cracks so off came the timing cover and hello coolant.
    i've ordered a timing cover and thinking about getting a timing set and new water pump just to go with all the new gaskets and thermostat, that way it's near new allround.
    i've got a new sump and pickup lying around too, so 1 leak and it's going on.
    Oh and it turns out she's got double row valve springs and aftermarket pushrods so i'm gonna get some roller rockers back on there..
  1. v6 heads
    By ramborf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2011, 02:39 AM
  2. vr v6 heads
    Last Post: 29-03-2011, 08:01 PM
  3. heads and cam.
    By VRV6BT1 in forum Yella Terra
    Last Post: 21-05-2008, 09:02 PM
  4. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  5. New Key Heads
    By Schooner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 11:58 PM
