Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By VR38
Thread: Compression test for a standard VN 5.0L V8
    raw
    raw is offline
    VN V8
    Feb 2010
    Default Compression test for a standard VN 5.0L V8
    Hey guys, I've got a standard 1989 VN 5.0L V8 and have just done a compression test
    The results were consistent, but seem to be VERY low
    Seven cylinders were 95 PSI and the other cylinder was 105 PSI (spark plug was darker than the others so I assume this cylinder had a bit of carbon build up which gave the slightly higher compression)
    What does it mean if all cylinders are this low on compression?
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Did you have the throttle fully open and was the battery fully charged before the testing?
    muttley383
    Evoke VE HSV GTS 6.0 auto, XR6 turbo ute.
    Aug 2011
    Mount Gambier, SA
    Is having the throttle wide open needed these days? Had my daughters VT Clubby 5.7 stroker done recently, and the mechanic didnt even get in the car, so no full throttle.
    Comps on that were all around the 200 psi mark.
    VB SL/E
    Dec 2008
    VR Berlina
    Jun 2010
    VIC
    i remember reading 150psi was normal for a oldish 304. how many kms on your engine?
    raw
    raw is offline
    VN V8
    Feb 2010
    The battery was fully charged, can't recall if throttle was held open - will have to ask (hopefully this is the reason for low numbers)
    Haven't changed the plugs for ages so when I take them out again I'll redo comp test
    Never done a comp test on it before so I've had nothing to compare it to
    It may be a VN but it's only done 110,000 legit kms
    It's running like crap and has the symptoms of either a head gasket or intake manifold gasket (there's nothing else it could be - I've changed/tested everything else!)
    Aug 2011
    Mount Gambier, SA
    VR38, I was watching when he did it, and just lent in the window, and turned the engine over.
    I actually turned it over for the last 4 cylinders.
    VB SL/E
    Dec 2008
    I use a chock such as a screwdriver to wedge the throttle open when working alone.
    vs 5L Berlina
    Jun 2011
    adelaide
    so what should the average compression be for a healthy 100k vs 304 motor as im about to do mine in the next couple of days just so ive got something to work from if i ever have any issues.
    VR Berlina
    Jun 2010
    VIC
    Quote Originally Posted by phear11 View Post
    160-170 would be acceptable. higher is better but what you want is consistancy over all 8 cylinders
    raw
    raw is offline
    VN V8
    Feb 2010
    Throttle was not held open during testing. Also found out the test should be done right after the engine has reached normal operating temp - mine was barely warm
    Will redo test on the weekend and post new reults
    Apr 2008
    Just curious, are you in Sydney? Would be interesting to do a DST (diagnostic scan tool) log on your car.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    My old one with well over 350k on the motor was around 140 - 150 pound. Went like stink though.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    my tuner just did a comp test on a VQ that was "meant to be a 360 stroker" lol. turns out most cyls were under 70 and two were just over 100 haha. That would explain why it idled so bad. Owner was dark as coz he just bought the car but anyway...
    told me that on average comp on a reasonably healthy 304 should be around 140's
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. Compression test v6
    By maccasparks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-11-2011, 06:55 PM
  2. Vs v6 compression test
    By juzzyx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2011, 09:14 PM
  3. how to do a compression test?
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2010, 09:46 PM
  4. Compression Test
    By Deutscher in forum General
    Last Post: 09-04-2010, 03:46 PM
  5. Compression Test
    By commy vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2010, 10:34 AM
