Results 1 to 9 of 9
Thread: Edelbrock 4 barrel throttle body 1000cfm ed3878
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Edelbrock 4 barrel throttle body 1000cfm ed3878
    I'm looking into getting one of these to go ontop of my torque power manifold.
    So far I've figured out it will fit and it comes with a iac and tps included. What I can't seem to find out it how im going to hook up my throttle cable.
    Do I need to make up my own bracket? Change cables etc? If someone that has used one that knows that would be great.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ill sell you my throttle body with iac and tps and throttle cable bracket, its a cvr cable bracket and efi hardware throttle body.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    I have an injection perfection one for when i efi my vh, it came with a standard vh cable.
    What sort of mount options do you have for the throttle body? you might get away with an early commodore cable and bracket seeing as it's essentially a carby shape setup you're going to use.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Boonz View Post
    pm'ed
    Quote Originally Posted by drewVHSS View Post
    Well i havent got the tb yet so im not sure. But im sure someone has had to install one of these before in a 2nd gen. I just want to know if its worth buying without a bracket/cable then trying to figure out how to get one.
    The Daily VN T5V6
    355 VN GRP A REP
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    they should just fit up to the holley detent extension bracket.
    edit* totally wrong link.
    look on holley.com
    VS SS
    Aug 2010
    ACT
    Just curious as I'm in the same boat myself can you keep the stock cable? The stock one will reach but is there any other problem that may cause?
    Boonz's Avatar
    Jul 2005
    stock one reaches no problems, only thing you need to do is extend the iac and tps wires
    vs clubsport
    Sep 2010
    hobart tas
    Smile
    G'day i have two 1000cfm holley's mounted on a tunnel ram I used a vr, vs throttle cable and took it to a cable place and they put a quick cupling on the end to attach to the throttle body also made my own bracket out of aluminium and mounted that on the throttle body
    hope this helps also have a pic but can't up load it but can send it in a email if needed cheers.
    ari666's Avatar
    1966 impala
    Mar 2009
    for those with autos, you can use this: Holley Performance Products GM AOD Kickdown Cable Bracket#20-95 to hook up your detent cable. otherwise manuals stock cables will fit.
  1. [QLD] Wanted - 1000cfm throttle body and dual plane low rise manifold for 304
    By shanbeau in forum Swap / Wanted to Buy / Trade
    Last Post: 21-10-2011, 07:46 PM
  2. vz v6 throttle body
    By ThunderKid in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-04-2011, 09:48 PM
  3. [NSW] FS torque power dual plane/1000cfm throttle body
    By chaos 8 in forum Parts And Other Items For Sale
    Last Post: 15-08-2010, 11:03 AM
  4. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  5. [WA] WANTED : 1000 cfm 4 barrel throttle body
    By blaze in forum Parts And Other Items For Sale
    Last Post: 05-04-2009, 04:09 PM
