the crank spigot holes are different sizes from trimatic to turbo. early VB's and whatnot came out with T400's so if you use an efi block then use a 400 and the trans mount/tailshaft from that, otherwise just use the traumatic behind your 308 block. i had my traumatic build with better clutches etc and it help up againt my daily punishment really well.
also: stock VN heads will hit 150 no probs, you wont even need a really big cam or stally. itll be a nice streeter. ol skool heads will mean you have to go a bit more nasty with everything and it starts to become a pig to drive around town.
cheer syea im not keen on a pig, just after a grunty cruiser...
seems it might just be easier to do a head swap after all.
yeah man just freshin the bottom end, vn heads cam an manifold should do the trick
Cheers lads now I just needa hunt parts... Grrr money!
Wanted to buy VC sunroof
Pm me
What did you do for compression??
Pm me
Thanks bro.
Pm me
