I want to overhaul my whole cooling system, just seeing if i missed anything or if there is something else i should replace.
I plan on changing the raidiater,water pump (with electric item), replace clutch fan with thermo's,replace heater core and tap,hoses. Flushing it a few times before i start also
WTB:VR/S HSV 250km/h speedo cluster
is there an additive that u can use to flush the system and release all the sludge built up in the water journals?? if so let me know im interested if there is one
Take the plugs out of the side of the block is the only way to flush it properly IMO.
There are a few cooling system flushers but most you need to add to ur system then flush out after 5000k's or so
