Page 1 of 3 123 LastLast
Results 1 to 25 of 62
Like Tree5Likes
Thread: (308) Building my motor.
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Default (308) Building my motor.
    Thought I'd open a thread to help with the build of my 308.
    I currently run a 253 ( sick of it. ) so I've organized a 308.
    I'm dreaming of 200rwkw but to be realistic.. i guess 150-170ish?
    The funds for this motor will be my weekly pay check which ranges from 250-500 a week. So i guess saving is a option when it comes to the expensive parts.
    So i have a suspected 'blue motor' block.
    Recently Hot tanked and honed with a brand new crank.
    Where do i go from here fellas?
    Current project; VH SL/X known as "NFNSUS"
    Ready for a overhaul due to licence issues
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    ^ Correction. Suspected RED block.
    Also bored 40tho over
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Flat top pistons
    VN heads
    Harrop or torque power dual plane manifold if going carby fed or using carby shape TB
    reasonable cam
    ST 2032 (non adjustable roller rockers) or ST 2033 Adjustable's
    308 vc
    Dec 2010
    North east Adelaide
    ^^exactly what he said.. Keep us posted with pics and info, keen to see this done step by step.
    Wanted to buy VC sunroof
    Pm me
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    May take a few weeks for each post but will do.
    VB SL/E
    Dec 2008
    Select a cam that will make approx 200kw that you can live with, cam selection will be the most important steps in the build, have your builder match the compression ratio to the cam and enjoy.
    As the other guys have stated, VN heads will make good power but maybe a bit lazy on a stock stroke 308 with a carby.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    forged flat tops
    crane 286
    YT 1.65 roller rockers
    harrop manifold
    quadrajet
    VN heads
    pacemakers
    2.5" twin dumped at the diff
    MSD dizzy, 6al and blaster coil
    3000 stall converter
    3.55 diff gears
    and a LOTTTT of money saved for fuel.
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Noted.
    Now to make a price list. :/
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    By twin do you mean twin system or just twin tipped? O.o
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Should be an interesting build.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    308 vc
    Dec 2010
    North east Adelaide
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by ari666 View Post
    forged flat tops $600
    crane 286 $500 inc anti-pump lifters
    YT 1.65 roller rockers $700
    harrop manifold $700
    quadrajet $50 bucks, then $150 odd to have it built
    VN heads $350
    pacemakers $700
    2.5" twin dumped at the diff maybe $1000, probably more like $1500
    MSD dizzy, 6al and blaster coil dizzy $250 6al $400 coil $90
    3000 stall converter $900
    3.55 diff gears if you are really lucky $500, but you will have to watch ebay for AGES
    for you. xxx
    twin system of course, silly. twin tips are just gay. and you wont see them anyway exiting b4 the diff
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Aw
    I have two blingy 3" dump tips, what I waste.
    Thanks for the prices!
    ari666's Avatar
    1966 impala
    Mar 2009
  15. #15
    VH SS
    May 2009
    Toowoomba, Qld
    forged flat tops
    crane 286
    harrop manifold
    quadrajet
    VN heads
    pacemakers
    3.55 diff gears
    I agree with your list apart from the MSD stuff. Nice, but not necessary considering he's on a fairly tight budget
    Factory blue/black HEI distributor/ignition will be every bit as good on this combo. Agree on the coil though, the Bosch coils are crap now they are made in China.
  16. #16
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    forged flat tops
    crane 286
    harrop manifold
    quadrajet
    VN heads
    pacemakers
    3.55 diff gears
    good choice of combo with 10.5:1 comp maybe 11.1...id go a solid cam instead!
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
  18. #18
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    After a LONG wait, my motor has finally arrived!
  19. #19
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Motor came with a 272 solid.
  20. #20
    308 vc
    Dec 2010
    North east Adelaide
  21. #21
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    At the moment mostly everything is stock.
    Hot tanked/honed red block
    272 solid cam
    Brand new crank
    stock heads
    stock manifold
    and so on..
    So i've been told.. knowing my luck, probably a load of bullshit but ohwell.
    Bought it in pieces. Wanted the experience of putting a motor together. Parts list is above ^
  22. #22
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    just sent this by the mate that went and picked it up..
    hmm.
  23. #23
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Well.. I got ripped big time.
    Thinking that just a 308 is kind of pointless.
    Considering it'll be roughy what.. 5grand? Thinking of going 355 instead?
  24. #24
    drewVHSS's Avatar
    Apr 2010
    so what came with the bundle to make you feel ripped?
    you'll have to prep your block either way 308 or 355 so it's not much more to relieve the block for stroker clearances whilst it's being prepped.
    you have a choice to either go with the solid cam setup and red heads or sell off the unneeded bits and use vn heads
    do you have the patience to check your clearances and lash for a solid cam setup? if not... probably wiser to sell that cam and go for a hydraulic one or a roller setup.
  25. #25
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    The pistons are all seized, the manifolds corroding, cylinder bores need to be re-honed. Heads need a lot of attention and so on.
    I'm thinking of taking the block down to the machine shop and asking if it's worth stroking it. If not I guess I'll stick to 308?
  1. Help building a new PC
    By AirStrike in forum The LAN Lounge
    Last Post: 22-05-2012, 12:24 AM
  2. 202 block preping. Building a motor.
    By seq4x4 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-02-2011, 09:54 AM
  3. [202] building 202 red motor
    By GYL3R in forum Straight 6 Development And Modification
    Last Post: 14-06-2010, 11:55 AM
  4. So i'm building another box
    By Fun_Bucket in forum Car Audio
    Last Post: 03-10-2009, 09:51 PM
  5. building a sub box
    By Sully72 in forum Car Audio
    Last Post: 22-03-2005, 09:34 PM
