Just changing the T5 from one motor onto another, and using a different clutch. It isn't new, but isn't very old either. Any idea how I go about adjusting the pivot point of the clutch fork so I don't put it all in and have to rip it back out again to re-adjust it?
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
i did this on sunday
adjust the top of the ball to teh face of the bell housing 101-103mm and it should b sweet mine was about 7mm out and it really did make a differance
Thx mate. How do they become "out of alignment"....surely it doesn't screw or unscrew itself hey? So if I put it at 102mm I should be sweet? lol
take the bellhousing off the gearbox, bolt it up the the engine with the clutch kit in place. Then setup the pivot ball height as required before you bolt the gb back on. easier to put on and take off a bellhousing that a whole gb!
Tried and tested![]()
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
