Results 1 to 18 of 18
Thread: efi to carby fuel system
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default efi to carby fuel system
    My VK wagz is running a VL fuel tank, VR intank pump and return line as we converted it to EFI. Now gonna go carby for a while, so what would be the best way to get the fuel up to the motor?
    I don't wanna rip the whole lot out. Can I just keep using the EFI pump? I'm using a Barry Grant return reg (for carby), but is that capable of running with so much pressure through it? Or will I have to change to a smaller carby fuel pump? If so, can I just use a VL intank low pressure pump, to feed an external Carter Black or sumfin?
    Any ideas?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    NAAAAHHHH MAAANNN!!!
    lol. AFAIK you can get either a 0-15psi reg (carby) 10-45psi reg and efi regs (100ish) 10-45 is too much for holley or quaddys even if you tweaked it right down, itll still push past your needle/seat
    of course im willing to be wrong, just stick a mechanical pump on it!
    DANNY8's Avatar
    Apr 2004
    The reg I have I assume is a 0-15psi reg. So can I use that and set it at say 6-7psi? If there is 45psi coming at it from the EFI fuel pump, will it still work sufficiently using the carby reg? I don't want to run extreme fuel pressure, it's just the EFI pump is already in there, and as I will be changing back to EFI in a month or 2 I don't want to swap it all over unless I really have to.
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah i was speaking to a guy at VPW about this when i was looking at fitted the 454 with a carby (to keep costs down till i could afford to go full efi) he said that the 0-15 holley reg wouldnt be able to cope with the 115psi pump i would need for EFI. he reckoned the seals in the would crap out and it'd end up dumping too much pressure in eventually.
    whether he said that to make a sale of a 120 buck carter black pump, im not sure. either way i decided not to do it. i would be dead keen on knowing if that reg could cope, cos then i can start messing with my fuel tank while still running the 327.
    my plan was a bosch 044 with a surge and return. one thing i did wonder though was: what would happen if i just put a splitter on? i.e. a t piece where the fuel line runs straight to the reg and in the same fitting runs the return line. surely all excess pressure would just feed back to the surge?
    DANNY8's Avatar
    Apr 2004
    What if I run a VL low pressure internal pump, which feeds a Carter black....I guess that would work.
    I don't wanna run a mechanical pump. I'm over them....and I'm not even sure if the cam has a fuel pump eccentric on the end of it, as I built it for EFI.
    ari666's Avatar
    1966 impala
    Mar 2009
    ah yeah. that would be a bit of a problem...
    those VL intanks are pretty gutless. think they are only around 4psi. you dont need a pump in tank for a carter black, you just install it below your tank. i.e. assembled to one of your tank straps.
    DANNY8's Avatar
    Apr 2004
    But then I still need a sender to fit the EFI tank. If I use carby sender with no pump, just the pickup tube, will it fit inside the EFI tank?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Use the EFI pump with a good regulator with the return line and it should be fine. Holley do one Holley Performance Products Two Port 4.5 - 9 PSI Bypass Style#12-803BP
    Visit my Facebook page
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    hey mate did you ever have the engine problem like my self and nasty1 did?? (idling bad,running like it was down on a cylinder)
    My VL Walkinshaw replica project
    ari666's Avatar
    1966 impala
    Mar 2009
    hmmm, not sure. they are very similar shape and size. i thought they were identical except later models had the filler tube affixed with a rubber joiner and VK/VL etc were soldered onto the tank...
    you can use the carter with the efi pump still inside the tank. my intake died and i didnt ever bother taking it out of the tank, just cut power to it.
    i think i may now be getting very confused.
    DANNY8's Avatar
    Apr 2004
    Well I might just give it a crack using the reg and see how it goes.
    Here's a pic of it...haven't got a close up. The whole fuel system in the pic come off a carby 355, and got it for me other wagz, but just using the fuel log and reg on this donk for a few burnout comps. I guess it'll either work or it won't lol....one way to find out.
    Attached Images Attached Images
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by *uwishn* View Post
    Yeah the old EFI motor in the wagz seemed to have a miss on idle, but cleared up as soon as the foot went down. Still not sure what it was. Built a new motor for the wagz, and the EFI motor out of it we're putting into a GQ Patrol shorty, but gonna rebuild it anyways. I still rekon a valve was dodgy, will check them out when we rip it down.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Quote Originally Posted by DANNY8 View Post
    Any ideas?
    Intank low pressure pump may be good enough to run it by itself.
    The VL 6 cyl internal pump is the same part number as the intank pump on VK brocks and VL carby fed 308's. Put your original VL internal lifter pump back in and you'll be ok for a stock motor as i've seen heaps of the later carby vl's have only the internal pump. You could also chuck on an early timing case cover and use a mechanical pump for a while. My VH SS only uses a factory high volume mechanical pump and my motor is far from standard, no fuel starving issues either.
    SS
    Jan 2012
    Australia
    Might need a large return line if your going to overload the reg, pushing 40odd PSI into reg and only 7 coming out the other side.
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by drewVHSS View Post
    i disagree. my VK internal caused me all sorts of problems which i only figured out once i finally got rid of it.
  16. #16
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by Westie View Post
    Even on an EFI setup, most of the fuel is going back to the tank anyways, it just needs more pressure in the rail. So the fuel going back to the tank should be similar whether it's EFI or carby.
  17. #17
    DANNY8's Avatar
    Apr 2004
    Ended up swapping the high pressure EFI intank pump for a VL intank low pressure pump, and that feeds a carter black (14-16psi), the reg is set at 5-6psi, and so far it's been working good as far as I know.
  18. #18
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah i was thinking about that the other day. if you stick a holley fuel reg, even though it has two fittings, one is NOT a return line. if you restrict the pressure to 7 or 8 psi, then BOTH the outlets are running on 7-8psi.
    just sayin'
  1. Straight gas system for high performance 355 stroker - fuel system advice needed
    By Darran76 in forum V8 Development and Modification
    Last Post: 20-01-2012, 05:08 PM
  2. VK Black 202 Carby / Vacuum System Problems
    By Mad84VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2011, 03:20 PM
  3. Carby VK not starting...getting spark & fuel
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2010, 06:24 PM
  4. 304 fuel injection to carby conversion
    By nera in forum V8 Development and Modification
    Last Post: 20-09-2010, 03:02 PM
  5. Carby not squirting out fuel.
    By DANNY8 in forum V8 Development and Modification
    Last Post: 24-03-2010, 09:51 AM
