Results 1 to 4 of 4
Thread: are 276 cams all right?
    vh commodore,Holden captiva
    Mar 2012
    adelaide
    Default are 276 cams all right?
    Been talking to a mate that builds engines and has told me with my engine which I like to keep on gas I should go with a 276 size hyd cam.
    I would like it to be more cammy like maybe using a 286 but he reckons on gas it wouldnt be worth it?
    this engine would be a mild engine running l34 heads flat tops and on gas with a small stall
    AUTO PAINTER
    PEARLS MICAS AND SOLIDS
    CONTACT GARTH 0412 326 688 ADELAIDE
    ANYONE UP FOR A EARLY COMMO CRUISE
    vx ss 5.7
    Jun 2012
    Ive ran the 276 on straight gas before and it had a nice mild note and was ok for a daily! I took the base plate with butterflys of the bottom of a halley carby and took the impco 426 unit off the snorkel and bolted to the baseplate and ran the gas system as a carby as i had tourque power man and couldnt shut bonnet in vl with the gas unit on carby. Hey whos gonna build for ya champ?
    Mar 2012
    adelaide
    I have a friend that builds engines for burnout comps so he assemble it and his mate Tony Knight will do some machine work for us
    AUTO PAINTER
    mr j-man's Avatar
    mr j-man is offline \m/ \m/
    VH SL/E 355
    Oct 2010
    In the garage or at the pub.
    Quote Originally Posted by vhgasser View Post
    just talk to TK ..... he'll point you in the right direction.
    what do u mean by more cammy?
    are u after that lumpy note?..... if so you have look at your LSA figures
    when you go up in cam duration @50* all u r really doing is shifting the torque bracket higher up the rev range
  1. 304 cams
    By mr calais 5.0 in forum V8 Development and Modification
    Last Post: 19-02-2012, 04:59 PM
  2. Howard cams vs comp cams
    By sickooli in forum VE Holden Commodore (2006 - 2013)
    Last Post: 22-05-2011, 02:37 PM
  3. help with cams
    By idb in forum V6 Development And Modification
    Last Post: 19-07-2009, 04:15 PM
  4. VS V8 cams
    By craney in forum General Discussion
    Last Post: 18-03-2007, 03:43 PM
  5. Cams
    By DVS87 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2006, 06:11 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
