Results 1 to 14 of 14
Thread: Need help re removing and installing v8 auto transmission vt v8
    VL FORMULA
    Sep 2008
    SUNNY COAST QLD
    Unhappy Need help re removing and installing v8 auto transmission vt v8
    Hi looking for help or threads in relation to removing and installing
    an auto gearbox to suit vt v8
    VL FORMULA
    Sep 2008
    SUNNY COAST QLD
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    VL FORMULA
    Sep 2008
    SUNNY COAST QLD
    VL FORMULA
    Sep 2008
    SUNNY COAST QLD
    I just thought being the first forum that comes for holdens you guuys would be mad holden fanatics with expert advice
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by soquilichi View Post
    Thats exactly what happens here, but people don't spend their life sitting at a computer waiting for people to post their problems. I'm sure you will get a constructive answer tonight, but it won't be in the first 10 minutes.
    VL FORMULA
    Sep 2008
    SUNNY COAST QLD
    Hahahah awesome, thanks heaps hey, cant wait to get this thing cracking and certainly need the help of a holden man
    ari666's Avatar
    ari666 is offline Jose Arimeintes
    1966 impala, 2011 chevy camaro, 2007 silverado
    Mar 2009
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    showbags's Avatar
    showbags is offline SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    Dec 2009
    ari666's Avatar
    Mar 2009
    ok, constuctive post:
    undo pan bolts and drain fluid
    undo the inspection plate
    undo the 3 torque converter bolts and slide the torque converter all the way towards the transmission
    undo tailshaft bolts (and center bearing holder) remove tailshaft (remember to put a oil pan under the spline cos a shit tonne of fluid will come out)
    undo linkage from the passenger side of the transmission
    at some stage you will need to undo the cooler lines, depends on your car, mine needs to be done from the radiator and comes off with the trans.
    undo the transmission mount bolts and support the nose of the trans somehow (additional jack, blocks of wood, transmission stand, whatever)
    undo the 7 bolts around the housing. 2 on the drivers side, 2 on the passnger, one at the top and one staggered each side down.
    with the transmission thoroughly supported rock it up and down side to side until the locating pins on both sides work loose.
    then its just a case of lowering it out.
    i may have missed a stage or 3, so sue me.
    383 hatch's Avatar
    383 hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    I'll give you a tip, let someone who has a hoist do the job for you. These are big, heavy transmissions and not the sort of thing a beginner would want to be doing in their drive way at home with just a trolley jack (assuming you even have a trolley jack...).
    vt
    Jun 2012
    yandina
    Hey thanks heaps, husband is happy for this help, I will pass it onto him, he been harassing me all day to check his posts. Much appreciated hey
    ari666's Avatar
    Mar 2009
  1. vr transmission installing problems
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2011, 12:06 PM
  2. Removing and Installing Window reg VN
    By binx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:34 AM
  3. Installing transmission.
    By -scyth- in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-04-2009, 07:11 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 04:14 PM
  5. removing and Installing help
    By Arth in forum Car Audio
    Last Post: 29-06-2005, 09:23 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
