Results 1 to 5 of 5
Thread: identifying 355 stroker
    suddenimpact Guest
    Default identifying 355 stroker
    Hi all
    A mate of mine recently bought a 308 which he was told was stroked to 355.
    Now- eveything else looks standard 308 equipment except for the inlet manifold.
    Can someone please tell me a surefire way to identify if it is fact a stroker.
    cheers
    Tim
    angelo.vs's Avatar
    angelo.vs is offline Autobot
    Honda Accord Euro Luxury
    Oct 2003
    Hey dont take this is as gospel but Im sure theres no way you can identify if the engine is a stroker unless you open it up and check the internals.
    madmick Guest
    stomp it and see what happens
    also it should have a reasonable sized cam.. have a listen to the exhaust note and it should be lumpy... if it doesnt, get him to rev it then back off and you should notice it then.. (heard a v6 with a cam, idle you couldnt hear it, done that and you could hear it as it revved down).
    VR Caprice
    Dec 2005
    RACE5L's Avatar
    RACE5L is offline Solid cammed
    VH 355
    Sep 2004
    Feed a cable tie down the sparkplug hole and measure longest length without it bending, whilst someone manually turning it over till piston reachs bottom, do the same to a stock 308 and measure difference, or drop oil and have a peep through hole with torch and look for holes drilled on crank weights. Only real way is to rip off sump or head.
  1. Identifying IRS?
    By Kstar. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 10:04 PM
  2. Help Identifying
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 09:04 PM
  3. Identifying VN V8 engine parts
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2006, 06:34 PM
  4. Identifying 3.8 V6 Origin...
    By Flamenco in forum V6 Development And Modification
    Last Post: 21-11-2005, 04:40 PM
