Hello all,
Just wondering if anyone has hooked HZ pollution gear onto a vac seconds style holley carb?
Can the vacume line from the canister simply be hooked up to a direct vacume source on the carb or is it more complicated than that?
cheers,
Steve.
I assume all vacume is the same. Dont see why not?
Holley make a range of street legal emissions carby's. Just hook the vacuum line to any manifold vacuum point but not that has any other line coming off it as this robs vacuum needed for the carby. If you have a race style Holley then it will have no provisions for pollution gear.
Its a vac seconds 600 and ive just hooked it onto a vac point. seems to work fine. cheers for the help.
