Results 1 to 22 of 22
Thread: Rockers and valve springs
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question Rockers and valve springs
    What options do we have for the 5L? Near-stock application.
    Sam
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Really? Nobody knows anything about possible valve spring upgrades for the 5L, or maybe high-ratio roller rockers or similar??
    These just seem like a good (cost effective) way to freshen up the heads, or am I entirely wrong? What benefits do they have in terms of what you'll notice on the street?
    Any info appreciated
    Sam
    vn calais, vs clubsport #137
    Jun 2005
    dude. the setup on my car was a kit from crow cams
    you get valve springs, lifters, collets, a stage three cam, and a memcal for a decent price. goes alot better. its an easy place to start from. have a look at them mate.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I'm not really looking for a cam though... Daily driver and I don't want to blow my fuel economy. Don't get me wrong I'd love to slot in the lumpiest cam I could get my hands on, it just wouldn't be practical for me.
    These were just ideas to give the top of the motor a little freshen-up. No good?
    VC,VK, VN
    Feb 2007
    higher ratio rockers and a set of extractors will pep it up a bit. get it a good dyno tune.
    You should'nt need new springs.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by stroke it View Post
    Now if only there were higher ratio rockers to suit a 5.0
    Selling FG G6E Turbo and buying a N/A Supra
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by savage1987 View Post
    If your worried about fuel ecconomy, drive the 6. No one buys and mods an 8 because its good on fuel.
    '97 Lexcen Wagon
    Sep 2007
    Perth, WA
    Quote Originally Posted by AirStrike View Post
    Right, but that doesn't mean people aren't allowed to buy and mod an 8 and also want to keep an eye on their fuel economy. Plenty of people have good reasons to have a V8 as a daily driver, so being worried about fuel economy is legit.
    VC,VK, VN
    Feb 2007
    Well the standard rockers are 1.6:1 Yella Terra supply a 1.65:1 ratio.
    There are other ratios provided by other manufacturers.
    I have JBA 1.7:1 rollers.
    the thing is, its the new trendy thing to fit higher ratio rockers as it substitutes a cam swap to a degree.
    I believe personally that the valve lift should be controlled by the cam profile, with the cam designed with those particular rocker ratios, but each to thier own.
    Theyre actually designed more so to reduce side loading on the stem and reduce inherent friction in high load applications where the standard stamped rocker cant take it.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    So you can get higher ratio roller rockers for the 5L??
    OK it's question time:
    No re-tuning required right, they're just a bolt-on swap?
    Do they fit under the standard rocker covers?
    Power gain / practical difference? Good move on stock engine?
    What's a set worth and who can I go through to order some?
    Once again, any info appreciated as I've never really had anything to do with head or valvetrain work before - everything I've done has been external bolt-on parts.
    Sam
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Can you get roller rockers from anywhere reputable for the 5L? High ratio would be nice, but rollers are just all-round better, right?
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Standard is actually 1.63:1
    vnss
    Jan 2007
    wyndhamvale vic
    mate grab ya phone book and call someone like yella terra or come or hps for xample have a chat to some one who does them every day....
  15. #15
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    To put it simply mate, $$$ vs Kw its not worth it. We gained about 6rwkw in the very top end of the power scale (over 4800rpm) on my SS.......and that is with YT billet adjustable rockers of which are worth around $950.
  17. #17
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    ok fair enough. I was just wondering what I can do to freshen up the heads a little bit.. I've never had anything to do with this particular area
    I know the roller rockers are pretty popular with at least the Ecotec engine, I thought maybe they'd be good for a 5L too..
    OK well that just leaves me with the question about valve springs. Worth doing? Engine has around 270,000km and a fair bit of hard driving under its belt...
    WTB: mulberry VN interior parts
  18. #18
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Are you getting valve float up in the top of the rev range?
  19. #19
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I do not know what that is. Nearest thing I've heard of is valve bounce.. similar thing?? Seriously I'm interested to learn about this valve float thing.
  20. #20
    Jun 2005
    Valve float and valve bounce are the same thing just different terms. If its suffering from valve float/bounce then by all means replace them. If not then they should be fine, however at 270,000 they will be getting fairly tired so it wouldnt hurt to replace them if you want to.
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    How do I tell whether I'm valve bouncing or it's just a rev limit?? My VN V6 I'm pretty sure bounces but I'm not 100% (not surprising with 420,000km on her ), the VR seems to do a similar thing but it could just be a limiter...
  22. #22
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Any takers? I don't know how to tell the difference.
  1. F.s 918 Valve Springs
    By spanks in forum Parts And Other Items For Sale
    Last Post: 07-10-2007, 08:23 PM
  2. HD Valve Springs
    By Not_An_Abba_Fan in forum V6 Development And Modification
    Last Post: 04-04-2007, 04:39 PM
  3. LT1 valve springs and crane valve locks
    By lxhatch in forum Parts And Other Items For Sale
    Last Post: 30-03-2007, 06:50 PM
  4. do i need new valve springs
    By joshsvs in forum Yella Terra
    Last Post: 08-03-2007, 03:09 PM
  5. valve springs
    By vulss1ute in forum LSx Development and Modification
    Last Post: 04-11-2005, 12:26 AM
