Is there any difference between the VN 5L fuel rails and the VT 5L fuel rails.
I'm fitting a set of 36lb super 6 injectors, and to fit the VN 5L fuel rails, need to cut a slot in them for the injector clip. I heard a while back VT fuel rails where different, was wondering if this is true? and how different?
Hot Lap Motorsport
VS rails are different I know that but not sure on the VT, also I'm not sure if the VS ones will help, they have a round bit to clip the injector in rather than the square one on the VN/P rail
AGRSSV will be able to tell you the difference on them he has VT ones in his vn ss, i would go something from enchanced automotive EG a custom option if u want the results.
Cheers.![]()
* RVN 355 *
i think VT ones are the same as VS, but different reg and the cross over pipe is alloy compared to a steel tube.
no need to go custom, standard fuel rails could easly support over 1000hp, they are 1/2id.
http://www.youtube.com/watch?v=rute6aV3nN0
Top gear @8500rpm
