im missing a bolt out of each engine mount, the bolts that go into the motor itself. is there anywhere i can buy these individually?
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Yes you can, just go to Coventry's and ask for another one. Its easier if you know exactly what size bolt you are after.
Or you could try a reputable tool shop, they normally have plenty.
Or you could try a Wreckers, now they would have plenty
does anyone know what type of bolt they are exactly? its for a 5 litre VR
Go to a bolts shop or something like dandy fasteners i'm sure there's one around your area . Finding out length and thread pitch and size is your next problem. You drive there take one out and show them then put them back in your car
Originally Posted by Smidy
Yup, I was going to suggest something similar - take one out, show them, and ask for another oneThere's a great place on Molan Street in Ringwood that should have what you're after.
The 1972 HQ Kingswood
Have to be careful though, as Holden V8's run 2 different size engine mount bolts. 2 are 14mm head and 1 is 16mm head....Make sure you get the right one!
Holdens should be able to look it up on the computer and possibly order them in. I recently got 2 main bearing cap bolts from them....cost like $1.50 each. The program they use pretty much shows an exploded view of every part and most times it shows a part number for every nut and bolt. You could get unlucky tho and they won't be able to get them....but yeah no harm in trying.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
I checked a couple of threads out today at work on some built motors they are 3/8 unc x 20mm deep these are the top 2 on the block, as TIm said there's 2 types so im guessing the bottom one is the larger but they'd all be 3/8 unc thread
No, the bottom one is a bigger thread also. I would say the bigger one would be 7/16 UNC....
cool thanks guys. ill go to a hardware store tomorrow and see if they have anything, although i dont like my luck
you rang?![]()
*slaps forehead* Stocky bolts come from bolt shops or engineering shops not hardware stores, not unless you want a cheap as galvinised bolt to hold your rose arch up. Holden will definatly have some too
nope holden dont make them anymore
just at work now and thought id take a screen shot for ya
No.9: 00454905 (Joint in SA has a couple and also a joint in WA has a couple)
No.10: 122246 (Obsolete)
