well today i was lookin under my vr ss while i was putting my exhaust back together and noticed a rather disturbing crack in my rear K frame set up 4 the irs...... there is a crack about 2.5 inches long across the center of it right above the diff. apparantly this is a common thing that happens to commodores with the early irs setup? the crack dose not look fresh so im guessing its been cracked 4 a while now. also i have been told its more common on lowered cars no so much standard cars as i haven't lowered it yet its jus running it 16 yrs of sag.......... so what would i be looking at paying 4 a new one? i have been told i would be wasting my time with a second hand one from the wreckers as its prob already cracked or if not prob will as soon as i put it in??? or is there an aftermarket unit u can buy that its strengthened to stop this problem?? any help would be greatly appricated
thanks guys
cant you just weld it instead?
The VR and VS get this quite often, if you can find an earlier one that's not cracked form a VP or VQ do that as they seem to break less often. They can be strengthened by welding a big plate right across the top. It's a pretty big job to swap one. Holden still have new ones so just go ask how much
yeah, try for a new one, if not look around the wreckers to see if you can pick up one in good condition
sweet as thanks guyssoooo if i was tricky i should ask 4 a vp or vq one if i buy a new one if they r supposed to be stronger???
went to my local holden dealership today and apparantly u can not buy a new irs cradle anymore 4 the models vp 2 vt they stopped production on theses parts in september 07 so i was told..... so now my options r to get a second hand one from the wreckers 4 $150 and weld sum plates top and bottom to strengthin it so it shouldnt break again.. they must be pretty weak as u can break them as easy as dropping the clutch.....
