hi guys,
just wondering if anyone could help me with deciding on a few things...
i have a 308 5L stroked to 355 with raised compression 9.75:1 forgies, ported heads with bigger intake valves, roller rockers stock ratio, double row timing set in a vr commodore,
just wanting to know what size fuel injectors would be a good upgrade (cc) and what pump would be good, is it worth getting a dual throttle manifold and what else would you recon would be worth doing to the engine to get great power keeping it naturally aspirated.
cheers
very similar configuration to mine.... im running 28lb cream tops,super 6 fuel pump with a torque power dual plane manifold and 4 barrel throttle body
what cam do you ahve?
Also, just to be pedantic, you had a 304, not a 308.....
i actually dn't hav the engine yet and it will be in pieces for me to put together in 2 days, the cam so far is to suit the kit but im gna change it to suit the tune to get best results....
oh i thought it was a 308, is that vs onwards?
if your lookin at forced induction then it might be worth looking at a boost friendly cam and a group A style manifold because it is easier,cheaper and neater to setup for similar power gains
nah wanna keep n/a but thanx for the suggestion.
Is the engine running out of fuel now where ever it is? I'd go a cam upgrade as well as injectors and pump.
When Holden changed to the black motor they were all 304's from there. VK on.
ok then, any reason why you went low comp and forgies?
i think multi point magna injectors should be ok with what u have a and a walbro intank pump should be heaps, i would definetly go the torque power manifold with the 1000cfm throttle body and if u want have your air cleaner just sticking out the bonnet looks tuff as
isnt 9.75:1 comp a lil raised... whats wrong with forgies?
i'll look into that manifold and injectors thanx.
nah just curious cos most peop[le who build a motor with forgies are lookin to throw some extra pressure in the cylinders... ive built my motor with forgies and to 9.8:1 comp cos im gonna put a blower on it. all i gotta do when i put the blower on is swap the head gaskets to a 1.6mm thick one to drop the comp a bit more...
most guys who build a N/A motor have the comp around 10.2-10.5:1 cos thats where they start making the big numbers
dont get me wrong 9.75:1 is raised, and still makes heaps of torque but doesnt make as good power as the higher comp motors
oh ok fair enuf, i think for my application my comp will b enuf, do you know roughly wat ur comp will b with the thicker headgasket, just to keep in mind incase i wanna go forced induc l8r...
should drop it to around 9:1 ish, which is nice for about 12 psi safely... which would be insanely stupid power for a live axle ute![]()
