+ Reply to Thread
Page 1 of 20 1 2 3 4 5 11 ... LastLast
Results 1 to 25 of 495
Like Tree44Likes
Thread: my vk berlina
    ari666's Avatar
    ari666 is offline celebrate disrepair ari666 W427 ari666 W427 ari666 W427 ari666 W427
    1966 impala
    Mar 2009
    Default my vk berlina
    hi all. here is my ride.
    VK 1984 berlina sedan
    white, vomit blue interior
    the HDT grille has been donated to someone elses car.
    308 5 litre L31 VK black motor pre-ulp VT engine prefix 9.2:1 comp standard
    inlet;
    16' air filter
    holley 750 VAC secondaries. brand new and SHINY grin
    edelbrock performer inlet manifold
    heads;
    yella terra shaft mount roller rockers
    hardened valve springs for to suit 500 lift
    .194 inlet vlaves 1.6 ex,
    unleaded seats
    throated, edges taken off throats then mildly ported to match throat widths, polished exhaust ports.
    chambers lightly deburred and brushed
    oil gallerys deburred and polished
    inlet and exhaust ports matched to manifolds
    heads decked down to the hieght indicator
    crack tested
    new k-lines stem seals etc
    cometic head gaskets
    exhaust;
    pacemaker headers
    2.5' redback single system
    internals;
    engine valley and gallerys polished/deburred
    crane 286 cam: 230 deg duration 496 lift
    crane anti pump lifters
    rollermaster timing chain
    flat top pistons, crank/assembly balanced
    carter fuel pump
    holley fuel pressure reg. 6psi pressure
    Z200 EFI fuel filter
    bosch dizzy, regraphed by scorcher performance who made the advance curve so spasticly high the most advance i can get static is 11 degrees
    Mallory coil
    mallory 6AL ignition box
    stock bosch plugs 6 heat range 1 mm gap
    bosch steel leads
    powermaster 140A alternator
    transmission;
    trimatic
    stage 2 shift kit
    2500 stall converter
    diff:
    3.55 LSD big salisbury 10 bolt
    reco'd standard radiator
    2x16'" craig davies thermos hard wired to 'on' position
    CVR powertorque starter cos' standard starters dont like pacemaker headers. i killed two starter motors finding that out
    standard VK sle alloy rims with crap tyres
    running on optimax
    v8commy is offline Banned v8commy Executive
    vk calais 5.0
    Mar 2009
    reynella sa
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake! DANNY8 Caprice
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS vkwalks39 Executive
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    very nice, go the vk's. how much power are you looking at?
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    ari666's Avatar
    1966 impala
    Mar 2009
    lol, i didnt realise people posted on this page. lol, ok well a few more pics anyway
    flat tops
    crank/block
    almost complete
    this block put out 110RWKW at its last dyno but i know for a fact it is a hell of a lot more than that now :P it puts a grin on my face... EAR TO EAR everytime is launches. cops like it too.
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    1966 impala
    Mar 2009
    i dunno yet. for some reason work has completely dried up so i am broke as f..k. its running a little on the lean side too so will stick a couple of bigger jets in it tomorrow then god knows when i can get it dyno'ed
    my target when i first started was 220HP at the wheels cos' then on paper it would beat a 32 GTR.
    you see, i work on japanese imports and my morkmates all poured scorn on me when i bought the VK saying "itll never go as fast as your GTR" which was stolen and with the insurance money i bought this instead with the idea that if it was stolen, i wouldnt care. but slowly i have been experimenting with mods to make it a bit of a weapon.
    anyway, it breaks out at 60kmph if i tramp it and drop down to 1, which makes me smile
    i would have to guess i hit the target of 220HP at the wheels but would really hope for more than that.
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    1966 impala
    Mar 2009
    lol, KW? not a chance. hp is being a little more reasonable but still not realistic. 300RWKW would be forced induction. i dont evn think the bathurst racecars had 300RWKW
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    1966 impala
    Mar 2009
    ari666's Avatar
    1966 impala
    Mar 2009
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    VZ SS ute and VC sedan
    Sep 2009
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by monsteroz View Post
    That is a very big carby for a 308
    yeah, thats why dyno guy said. next mod is a HP body for my 650 double pumper and single plane manifold. he said thatll pump it up around 20 horses at the fly, but wont make much difference to RWKW, maybe 5-10
  16. #16
    Sep 2009
    biggest problem with too bigger carby is lean problems at high revs.. or you are wasting fuel and down on horses... matched solution is best in this case.. bigger not necessarily better.. GO EFI
    Sean
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
    the whole challenge behind this build is to make a 308 to go faster in a straight line than a R32 GTR. the clauses are that it must be 308, not stroked, and carb'd. its a work thing, everyone still takes the piss outta me for modding a commodore...
  18. #18
    ari666's Avatar
    1966 impala
    Mar 2009
    so this weekend was a commitment of re-doing my inlet manifold, because i descovered that i could no longer remove my distributor ?!?! anyways, refitted the manifold without dramas, fitted a 1 inch phenlonic spacer, cut the choke horn off my 650 DP an ground it down nice an flat and fitted that.
    only to descover to my dismay that this carby is nowhere near setup for this engine in regards to power valve, jets, pump shots etc. so now i have to go through the whole precess of getting it all working efficiently again.
    *sigh*
  19. #19
    commodre 1982 vh sl
    Feb 2009
    melbourn
    nice car sucks about the carby
    Quote Originally Posted by rch-13z View Post
    no point going tt, it'll just get you a yellow or a trip to the EPA to get arse raped lol...
    my pimping vh sl
    http://forums.justcommodores.com.au/...k-frendly.html
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
  21. #21
    VH SS
    May 2009
    Toowoomba, Qld
    leave the Quaddy on and take the car to someone who knows how to set them up - you'll be much happier with the results.
    the power output does seem a little low for the engine work you have done. Are you sure the cam timing is spot on ? A couple of degrees out can really dull an engines performance
  22. #22
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah i dialled it in at zero. the cam card said 0.81(?) inlet lobe lift at TDC, thats what it measure up to @ 0 so thats what i did. advancing the cam with a matched lobes really doesnt achieve the same result as a cam with different lobe seperation, so i just left it alone.
    my thinking has moved to a possible rouge lifter or dud valve install height, but i CBF taking the manifold off again to check them so everything is staying as is till the impala is back on the road and i can take the time to drop the engine back out of this car.
  23. #23
    old mate's Avatar
    old mate is offline Circuit Racer old mate Berlina
    VS Ute
    Aug 2009
    The Racetrack
    Quote Originally Posted by Darren_L View Post
    agreed, quaddy's are a very underrated carb IMO, once you find someone to set it up, i bet you will be surprised.
    my old man is running a quaddy on his 360 stroker 308, but its nearly at its limits, and he is also using the edelbrock performer manifold. pretty torquey motor, revs about the same as yours going by the dyno sheet.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
  24. #24
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum Calaber W427 Calaber W427 Calaber W427 Calaber W427 Calaber W427
    VY II BERLINA
    Nov 2007
    LOwer Hunter Region NSW
  25. #25
    ari666's Avatar
    1966 impala
    Mar 2009
    wow, have not posted in here for a while... anyway. this is something i should have done months ago. there is a local smack head who keeps breaking into my car and f'ing the locks up. lets see him f' this one up eh?
    as you can see he stuffed the lock up:
    so instead of repairing it, i thought i would get rid of it altogether, since this car is remote central locking anyway:
    grindie grindie:
    after bog and some rubbing and some spray paint:
    and it turns out that my missus decision for the dash colour in the impala is a really close match to my VK's colour so thats pretty kewl
    am gonna block it back once its had a few days to dry. stay tuned for the drivers side
+ Reply to Thread
  1. [VIC] Wanted: Vy berlina calais bar or vz exec/acc/berlina/calais
    By josh.meaden in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2009, 06:59 PM
  2. Vx Berlina Grill On My Vt Berlina
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 06:47 PM
  3. Replies: 57
    Last Post: 12-10-2006, 07:47 AM
  4. vn berlina
    By Matty o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2006, 12:43 AM
  5. My VX Berlina
    By donz in forum VT - VX - VU - WH - V2
    Last Post: 20-06-2006, 12:11 AM
