+ Reply to Thread
Results 1 to 24 of 24
Thread: My vb sl/e chev conversion
    VS Calais & VS STATO 5.0
    Dec 2006
    deception bay
    Default My vb sl/e chev conversion
    Here is some pics and info for those wanting to do chev conversions to early commodores.
    Ill start by pointing out this is a budget job and by no means intended as show standard or the likes.
    I started with the purchase of my 79 vb sl/e, at the time of purchase it had a pretty tired 253 trimatic combo and i soon got sick of replacing fouled plugs and only getting 180-200k out of a tank of fuel so its time for an engine upgrade.
    pics of when i got it apart from the grill i changed that to protect the mint vb grill from damage.
    Now comes the fun parts, my dad had a 283 in his datto and went to a bigger 350 so we decided the 283 would look good in the vb as it was less then 10,000k old and better than the 253. The 350 came with a turbo 400 so we where intending on using that aswell but as it turns out we managed to pick up a good th700r4 for cheap so now thats the box of choice.
    Dec 2006
    deception bay
    So to continue .....
    List of parts i will be using to drop the chev in.
    Engine: 283-350 chev
    Gearbox: turbo 700r4 (out of vq statesman)
    Castlemaine rod shop conversion kit:
    Engine mount adaptors
    K frame spacers
    Steering shaft spacer
    turbo 700 gearbox crossmember
    Chev into early commo extractors non power steer
    sump
    Other parts:
    Gear reduction starter motor
    vb-vk non power steering rack
    vb intermediate steering shaft
    vb/c turbo 400 speedo cable
    B&M mega shifter or quicksilver shifter (dunno which one yet)
    Adjustable strut tops
    Once the old boat anchor was removed we set about putting in the k frame spacers and swapping over the steering rack for power to non power and put in the intermediate shaft spacer as well.
    We needed to take a very small amout of metal off the edges of the knuckle in the intermediate shaft as it wouldnt turn with the spacer in but it was less than 1 mm so we dont think it compromises the integrity of the knuckle at all. Once together we notcied the spacer was fouling on the firewall and needed a bit of a bash with the hammer for clearence but i got a bit over zealous in this part hehe and now it looks a bit shitty but that can be cleaned up later when the car gets a respray. any way heres some pics with no engine.
    k frame spacers
    oops little over board with the hammer
    I forgot to get a pic with the intermediate shaft in place before the engine went in sorry guys.
    It was at this point we checked how the extractors went and discovered that the drivers side went between the intermediate shaft and the chassis rail there for would have to be put in there before the engine went in.
    engine dropped in on worries at this point though the gearbox crossmember and mount would not line up with the mount bolt holes but ill get to that soon heres some more pics.
    More to come soon trans issues and dissy clearence issues.
    Jo3_Blo's Avatar
    Jo3_Blo is offline HZ Holden Fanatic Jo3_Blo Hitchhiker
    WB 1 Tonner, VS Ute
    Jun 2006
    VP Executive R-spec
    Jan 2005
    Thanks for taking the time to document this build since it's something that gets asked about alot
    RIP HSV Senator. Current 2003 Ford XR6 Turbo M5.
    Apr 2009
    Porirua, New Zealand
    Default More to come soon trans issues and dissy clearence issues.
    Nice looking project,
    With my old VC that had a chev in it had to bash the fire wall to fit an hei type dizzy (ie- big bar and a slege hammer )
    in my VK when i put the 350 in to it used a twin point mallory and it fits with out any clearence issues (mechanical advance). Have just brought an electronic pro comp (hope it works lol) dizzy and coil looks like it will clear with out much hassle.
    Im running a TH400 box had to make a little notch in the floor and put some 10mm spacers under the trans cross member so it sits the box abit lower with out hitting the floor also running a hurst shifter as its cable opperated and a single piece driveshaft.
    One thing i have found with using Chev's is keeping them cool is abit of a hassle with out a engine drivin fan (both have had electric) in my current one im running EF falcon double ones does the job ok.
    good luck with your car will be keeping an eye on your progress, wish mine was a chrome bumper one(VB,VC,VH).
    PS - Once you go CHEV you never go back
    HSV802 VR Senator 185i Manual.
    1972 HQ Premier w/ 400ci Chev
    Dec 2006
    deception bay
    thanks guys,
    The turbo 700 required some clearance on the floor bracing on the drivers side but only because we raised the rear to get more dissy clearance on the fire wall, we have already had a bash of the firewall and folded the lip flat but to gain any more i will need to remove the heater box and fan system which i will be doing at a later date.
    I have a procomp dissy and my dad has the same and its has worked fine for a while now.
    WE have run the 350 which will be going in on a 3 core radiator with single 16" thermo and it keeps it cool although it was running an electric water pump then but now has a hiflow edlebrock engine driven one so i am hoping not to have issues if it does i will be going with the ford fans my self as i have used them before and they are a great unit.
    Project is on hold at the moment as we have to finish putting the new setup in the car the 350 came out of as we have run out of room to do both lol.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling.... calais_cruzin Berlina
    92 VP Calais 3.8
    May 2006
    Gold Coast
    looking good trev, spewin u have to hold of for a bit to get her done.
    You really should get this 500hp nos kit for it tho, would go down nicely
    ________________________________________
    Dec 2006
    deception bay
    Dec 2006
    deception bay
    work will recomence this week after a bit of a delay so ill post up more stuff soon.
    red_vb's Avatar
    red_vb is offline i am a she, not a he... red_vb Executive
    vb
    Nov 2008
    Dec 2006
    deception bay
    Car went in for exhaust today when it gets back ill put up some more info and pics.
    Dec 2006
    deception bay
    pic of engine bay as it is now. still needs some bits and peices like lead holders alloy pulleys but at least she mod plated and going now.
    also have a vid of it straight out the extractors but as we where later to discover one of the plug leads was broken hence the bad miss. this was its first start since removing from the other car.
    YouTube - vb no pipes
    Attached Thumbnails Attached Thumbnails My vb sl/e chev conversion-mini-imgp2602.jpg
    holden calais vy s2
    Jul 2009
    Dec 2006
    deception bay
    not really apart from its going and registered/mod plated. sorting out a few clearence issues mainly around the gearbox and having carb issues. was running a 570 holley but just swaped it for a 780 but having spluttering problems at about 1/4 throttle.
    Took it out to willow bank and ran a 14.6 with the 570 on it but she's alot livlier with the 780 so next time it should be well into the 13's maybe even 12's with 4.11's and 3000 stall and maybe a 100 or 150 shot of gas.
  15. #15
    92 VP Calais 3.8
    May 2006
    Gold Coast
    ahh trev should puta 700 on it, grab this nos kit off, will drop that time down hahaha.
    Its progressive soo u can start her low like 5% of 500 n work its way up over 10sec's
    Will have to go for a drive up your way aye been a while since we went cruzin.
  16. #16
    vy sedan
    Jul 2009
    nice looking vb mate, was this down at willowbank a few weeks back on a saturday??
  17. #17
    Dec 2006
    deception bay
    yep it was.
    yeah jason you really need to come up one weekend we can hit the piss and have a yarn.
  18. #18
    92 VP Calais 3.8
    May 2006
    Gold Coast
    hmm im not doin nothin mite come up aye ill give yo a ring ay
  19. #19
    TrikkBen's Avatar
    TrikkBen is offline Compulsive. TrikkBen Statesman
    VY Series 2 Clubsport SE
    Apr 2009
    SE, Vic
    What kind of Sump did you use?
    Ben
    There is no such thing as stupid questions, Only stupid people.
  20. #20
    Dec 2006
    deception bay
    its the sump that comes with the kits from crs they are a ugly chunky sucker you can buy all the bits separately though.
  21. #21
    TrikkBen's Avatar
    Apr 2009
    SE, Vic
    If you are unhappy with it, and want to change it let me know.
    We build ASR pans as well as all the High Energy oilpan range.
    Ben
  22. #22
    v8commy is offline Banned v8commy Executive
    vk calais 5.0
    Mar 2009
    reynella sa
    hey not trying to be a wanker but you could have bought holden to chev engine mount adapters there cheap off egay like $30
  23. #23
    Dec 2006
    deception bay
    Quote Originally Posted by v8commy View Post
    never seen them for an early commo besides i didnt pay for the motor or kit they where a gift.
  24. #24
    vk calais 5.0
    Mar 2009
    reynella sa
    aww well who cares then hey
+ Reply to Thread
  1. SBC / 350 Chev Conversion for VB/VC/VH/VK
    By Bread_Money in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2009, 01:16 PM
  2. vh commodore chev conversion
    By pnishu in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2009, 12:30 PM
  3. 350 chev conversion
    By bad_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2009, 12:58 PM
  4. 350 chev vk
    By josh0 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2007, 10:46 AM
  5. 350 chev or 308
    By darkstar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-06-2006, 03:53 PM
