Engine:308 v8
transmission: 4 speed manual heavy duty clutch
diffpen diff, highway ratio
suspension: superlows i think?
body: stock
interior: stock
exhaust: stock
intake: stock
wheels: stockies
other info: picked it up cheap, going to register it later on and cam it maybe
ive had this car for about 3 weeks now, i got it not running, the gas line had been ruptured and i filled the petrol tank up and turned the key for a while, eventualy it coughed and spluttered to life, needed a tune and timing adjusted, now it runs fine, engine has no ticks or knocks, doesnt blow smoke, and damn has it got some power, i can pull a 2nd gear burnout no problems, and if i really try it will light 3rd aswell, i plan to lower it abit more, rear and side venetians, fix the front left quarter and door, lsd or lock diff, with 3.9 gearing as this gearing is way to top end, and a big exhaust so it sounds like a v8 should
sounds like you got some good plans for the vh. take it your loving the 308 eh? how good are they with a manual box =D
yeah theyre great fun, thanks man im happy with it
