Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 64
Like Tree10Likes
Thread: Vh sle 5.0l
  1. #26
    VH SS
    May 2009
    Toowoomba, Qld
    great work, tidy conversion!
    well you've seen it.... you've heard it....
    have you driven it yet!
  2. #27
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by Darren_L View Post
    cheers daz! yeah just got it all legit yesterday arvo. got the exhaust done yesterday too! i went with 2-1/2from the headers into redback 200cpi cats and merged the two 2-1/2's into 3" at the diff and a lukey hiflo muffler mounted just after it. i wasnt sure on the rear mounted muffler on how it would be but the xhaust dude reccomended it....dunno if there is any advantage to it. has no drone either..which is great!
  3. #28
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
  4. #29
    VHSLE/VXSS/VXEXEC
    May 2011
    my only criticism is your camera lol...but great job mate looks tough i like what youve done
    the good thing about getting older....more toysthe bad news more headaches
  5. #30
    vc sle, 600hp supra, vu ss ute
    Oct 2009
    i see the qld plates where are ya located mate id love to see this thing in the flesh
  6. #31
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by machone View Post
    haha i know the pics were taken with my phone cam. sometimes they turn out alright.
  7. #32
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    time to start considering some internal engine work!....but where do ya start???
    what could ya get/do for about 3-5 grand???.
    dont want FI unless its a 6/71...and that aint happening any time soon!
  8. #33
    VS Calais & vh sl
    Dec 2006
    deception bay
    keep saving and go 355, you could buy the stoker kit for that but you will need machining and balancing then tune....
  9. #34
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    as above.. i'd keep saving until i had enough for a stroker + heads + cam + manifold.
    what stall convertor and diff gears are it it atm? cos if u dont do much highway work then some lower gears/higher stall will liven it up a bit.
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
  10. #35
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    havent done to much research on a stroker setup as yet.
    what kinda cam setup would go with a stroker kit?
    doin this kinda work you have to rebuild everything and upgrade injectors, fuel pump, ect
    doin somethin like this youd have no change outa 10grand id imagine, the mrs already chopped off 1 nut from all the other work ive done...... dunno if i can sacrifice another..hahaha
  11. #36
    VS 5L M5 VS 6L M6
    Apr 2009
    maybe a cam + heads + tune might be the go. get a set of heads mildly ported with decent springs and roller rockers and skim as much metal off the face as u can to up the compression as much as possible. cos the efi 5L has some lousy compression ratio standard, 8.9:1 or something.
    this thread could be interesting reading Stock 304, Guide to choosing a camshaft
    a dual plane manifold with a 4bbl throttle body would also be good for a street setup but throwing one of those in the mix too could blow the budget
    Avoid cluey police
  12. #37
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    scored a clean virgin vs block...goin to build up a 355 from scratch with all the goodies to go with
  13. #38
    Vh 304 EFI
    Jul 2011
    Bedfordale WA
    Very nice mate. All the hard work has payed of. Looking at your perfect car makes me want to strip mine down an start again.
  14. #39
    VK SL (Calais Mock)
    Nov 2011
    very nice! how much that paint job set u back?
    Depends on the car.
    VK = Yeah - entirely.
    VL = Nope - epic write off. Crush the entire car and do the world a favour.
    Quote Originally Posted by vkberlina View Post
    253s arent even good for landfill, dont bother,
  15. #40
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by Tim89 View Post
    thanks champ, alot of stress along the way lol...but its worth it in the end! dont let anything stop ya!
  16. #41
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by Mad84VK View Post
    not too sure, i bought the car as a roller with the paint done bout 5yr ago, it has alot of imperfections but its good enough for the mo! i just had the engine bay cleaned up, welded ect and then repainted it just before i dropped the 5.0 into it.
  17. #42
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    new block just been cleaned up,
    oil tracks in the valley deburred and polished up,
    heads on the way (getn a full port job), sump on the way,
    stroker kit sittin there ready to be fitted at the builders.
    cam kit on order! (solid)
    starting to get the ball rolling...still a fair bit to go....chasing 500hp from this one
  18. #43
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    haha nice to see ya bit the bullet and went stroker .. .what kit did ya get and what comppresion will ya run. solid cam will be nice but youll have to learn how to adjust roller rockers .. 500hp should be easy enough if you got something like 10:1 comp and decent cam+heads. good luck mate
    If in doubt......FLOOR IT!!!
  19. #44
    VH SS
    May 2009
    Toowoomba, Qld
  20. #45
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    goin the whole hog on this one!
    scat crank(knife edged counterweights), hbeams, srp flat forgies, 4bolt mains, line bore, 30thou over maybe 40. full port n polish on the heads...was told the cast heads will flow max to about 580....so thats what their gettin. crane 288 solid, dbl row springs ect ect. harrop or TP little paw s/p hrise manifold...leanin towards the TP as it has more torque than the harrop apparently. 4grand stally and about 11:1 comp. freshin up the diff with some 3.55 gears.
    so im aiming for about 1.5hp per cubic inch. its goin to jack bros for the bottom end assembly and somewhere else for the heads....maybe! they said 500 is do-able....ive seen 308's pull 440 with a freshin up and mild head work so it shouldnt be too bad. my main concern is streetability...not really tho as it will only be a weekender with a trip to the strip and pwrcrz this year hopefully.
    Hey darren! whats the go with lakeside track....wouldnt mind takin it up there oneday! dont know where it is either.
  21. #46
    VY S
    Jul 2011
    Belmont NSW
    loving that motor...so shiny hehe
    Quote Originally Posted by showbags View Post
    Seriously dude, that threads over 4 years old. Did they give you a shovel when you joined up.
  22. #47
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by HERONVY View Post
    thanks bud the covers polished up alright i must say..6 hours of hard out polishing on the bench grinder...payed off in the end!
  23. #48
    Mar 2011
    roxby downs
    hahah i love it how things start as just a freshen up then nek minnit full blown stroker
  24. #49
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by juiceie vh sle View Post
    haha tell me about it! i read too many forums too much and get carried away with it all and never settle for anything as a simple freshen up....ive only got myself to blame haha. goin to be a slow build this one, hopefully have it ready for pwrcrz this year..if not ohwell!
  25. #50
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Just some updated pix after a clean,
    fitted the stock external door trims just to throw some more chrome on it and brake up the black!
    Attached Thumbnails Attached Thumbnails Vh sle 5.0l-img_20120227_125130-1-.jpg   Vh sle 5.0l-img_20120227_125254.jpg   Vh sle 5.0l-img_20120227_125644.jpg   Vh sle 5.0l-img_20120227_125223.jpg   Vh sle 5.0l-img_20120227_125301-1-.jpg   Vh sle 5.0l-img_20120227_125152-1-.jpg   Vh sle 5.0l-img_20120227_125322.jpg
    Vh sle 5.0l-img_20120227_125424.jpg   Vh sle 5.0l-img_20120227_125345.jpg   Vh sle 5.0l-img_20120227_125511.jpg   Vh sle 5.0l-img_20120227_125521.jpg   Vh sle 5.0l-img_20120227_125534.jpg   Vh sle 5.0l-img_20120227_125549.jpg   Vh sle 5.0l-img_20120227_125637.jpg
