Mate Thanks. Not sure what gearbox or cog you are refering to. I am running a T5 box. I used the oringinal inner cable an half the outer cable to the tranducer. I used a T5 gearbox end outer cable and joined it to the oringinal with heat shrink and reinforced it with hose and overwrapped it with duct tape. I worked out using the GPS that it was 15% too fast so I change the cog on the speedo cable drive from a 20 to 23 teeth. I works and the speed is spot on.
Picked up a set of these 17 x 8.5 ZR6s for the VK. Missing a centre cap if anyone has one.
Fitted Nexen 3000 245s front and rear. I am chasing some more 17x8.5 ROH ZR6 alloys if anyone has any for sale please PM me. Pete
looking good red , wondering though are you going to get the whole car painted properly?
Current project VH SL SEDAN 202
http://forums.justcommodores.com.au/...-83-vh-sl.html
Last project VH SL WAGON L67
http://forums.justcommodores.com.au/...h-wagooon.html
I have selected the paint shop to do the job and haggled a price. But unfortunately like all good paint shops they are busy. Could be 3-4 months away. I am not looking forward to stripping it all down but will be worth it in long run. I will orgaize all new rubber kits and bits and pices for it. It will be off the road for a least 6 months.
Had the beast dyno tuned. It was a bit hesitant and stalled. Comments where that the mechanical fuel pump is not capable of puming enough fuel. Best to upgrade the fuel lines to half inch and fit a holley blue pump and regulator. Should be good for 220rwkw.
821.8 Nm Can that be right?
Hi there, I am currently undertaking a project that you may be able to help with, I am wanting to restore my calais to factory condition as mine is the same as yours would you mind posting some pictures, while what manual is yours running? I am a little hesitant in what to run although it was ruining a LV2 with a M21 gearbox from factory, I was considering a T5 any suggestions as I am starting from scratch no engine or transmission it is a 334 pack
Any information your happy to supply would be great dan000_1@hotmail.com
Regards,
Dan
good result! And if it has fuel issues, then you can certainly expect some more yet
don't take much notice of the torque figure.
That's the torque figure at the rear wheels, not the engine- rw torque is multiplied by the diff gears.
Mate I think you have to establish a budget and work from there. Mine is a $30k+ rebuild. Spent about $20k so far and have a $10k budget for paint and body.
I think an efi 5litre, T5 and VL turbo diff is not a bad start.
I would also be doing all the suspension and upgrade the brakes.
Start your own thread and throw up some photos. You will get a lot more input from others.
Good Luck.
Today I have started the paint process.
Strip car to the shell.
Send to blasters to do all underneath + engine bay + door jams etc.
Then chemical strip all the paint off the panels.
Then off to the painters for prep and paint.
Reassemble with all new rubbers and parts required.
Hopefully back on the road by the end of the year.
Almost there. Another day to remove fuel tank, fuel and brake lines and bits and pieces.
I picked up another ser of 17x8.5 ZR6. So F#@king happy about that. I have a set of 16x8s for sale if any one is interested.
I spent a few hours just blowing out and vacuum the sand out of the car. It is so fine and just gets every where. Collected half a bucket. Cleaned all the residual glue in the boot that glued the carpet in. Progress.
Not much actual progress happening to the car. I have sold the getrag box and the old stroker engine. Now have the funds for the engine rebuild. I have been doing a lot of research. I will most likely go scat stroker kit, crane cam and roller rokers and a ported and polished heads done locally.
