Model
Febuary 1985 VK Commodore SL
Body Interior:
Cerulean Calais Interior
VK SS Center Console
Tacho Dash
Boss Kit With Auto Technica Steering Wheel
Custom Parcel Shelf
Stereo/Electrics
Panasonic Mp3 Head Unit
350w 6*9 Pioneer Rear Speakers
120w 6" Pioneer Front Speaker
2x 250w(100rms) 8" subwoofers in parcel shelf
500w 10" Sub Behind Passanger Seat
720w 4 Channel Boss Amp In Boot
Red Neons Under Dash(i was bored)
Engine & Mechanical:
Automatic Transmission
202 Black 3.3 Straight Six On LPG
2 1/4 Exhaust Without Rear Muffler
Car Lowered Front And Rear (Has Lifted A Bit Due To 17's)
Small Crow Cam For High And Low End Proformance
8.8mm Topgun Proformance Spark Leads Glossy Red
LPG Specific Spark Plugs (May change back to the standard ones next time cause they seem work better)
Borgwarner 3.08 Ratio Single Spinner (i miss my old LSD)
Exterior
Asteroid Silver Paint
Stamped HDT SS Grille
17 Inch Momo Extreme Replica Rims
VL Door Moulds
Security
Solex Locks
Central Locking
Alarm
Immobiliser
Others
Existing Current Damage
Slight crack in grille
2 Dings In Front Right Guard for same reasons above
Double Sided Tape From Door Moulds On Passangers Side (leaving it there since its slowly pealing itself off to avoid causing any damage)(slightly hidden now due to VL Moulds which sit higher then VK moulds otherwise it would be covered)
A Few Other little paint scratches/imperfections
Ding In Drivers Door Due To Stupid Little ****s Who Will Die If I Ever See Them Again
Car slipped of the jack and the rear drivers side rim is buckled since i had only just put it under the car when it fell, still drives with it on but i think ill put the stockies on the back again.
Stuff I Have But Havent Put On/In Yet
Pioneer Tweeters
New Rear Tail Garnish
Extractors
Pretty Good i rekon considering i brought it For $700 bucks and have only spend $3300 on it including buying and repairing it, Soon as i get a full time job this will come together so much faster.
Im not bothering to do a conversion to v8 or manual anymore as i have decided to buy a new car in 2008 either another VN/VP Series 2 Calais 304 or a VQ Statesman 304 most likly.
looks good mate your future plans make it sound like its going to be a beast
i've seen this car and man its nice as it is can't wait to see it finshed
looks like a good project, are you gonna keep it silver?
pretty neat vk, rb30 turbo would be much better than a turbo 202!
Going where no late model stato/caprice has gone before.... GAME ON!!
turbo the 202. i was going to get a vk just like yours for my project car but i got the hz. awesome car man can wait for it start transforming.![]()
andy
ill take you for a drive in it next week sometime, so you can actually see it go instead of looking at it up on a jack or car ramps.
Yea most likly im gonna keep it Silver mainly cause i like the way the dark blue pinstrip on it looks.
Yea i know but if i decide to turbo the 202 i'd try and go twin anyway.
Yea me either, its just a matter of time and money as im pretty sure everyone on this site understands.
Nice vk mate. I'll have to keep an eye out for it around Narre South!
I'm frequently going up to the shops in Amberly park/Casey central as its just around the corner so you might have seen me around thereI'll have to make a thread about my ride soon
I work at casey shops actually, so if you see a really loud dark grey Vk there that would be me, and yes you should make a thread, i like to see what other people do with there VKs .
it is alive......tis registered and roadworthy, now the real work begins.
LPG install on the 26th of feb, so sometime in between now and then i will be taking my exhaust & extractors off my other vk and putting them on this one and changing the intake manifold cause i think the one in it now got a hole in it.
LPG is installed and i have it back, gonna cruise around in this from now on, but it has no guts atm on gas they didnt tune it properly, doesnt matter will fix.
Wouldnt bother putting a turbo on a 202, if you want a turbo, turbo a rb30. But you cant go past a v8 vk![]()
pheonix21 took this when i was in the boot soldering the new speaker cables in, me in to boot drops it almost right onto the tyre![]()
2 & 1/4 Exhaust with Turbo Muffler being put on as we speak, going to pick it up in 2-3 hours, finally i can get rid of the stock put put noise.
EDIT: Damn only took 2 hours to do, got it bak at 2, sounds nice even without extractors
Looks nice, should be great when it's finished!
Also, I couldn't help but notice what appears to be a WB Staesman in one of the pics, do you have a topic for it?
FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
http://forums.justcommodores.com.au/...ressively.html
