Results 1 to 3 of 3
Thread: VK motor for VH
    vh
    Nov 2007
    Default VK motor for VH
    My son has a 1984 VH with a 173 motor, 4 speed man, he wants to fit a VK fuel injected motor. Can anyone tell me if it's a straight swap or how much messing around it will be. He wants to maintain the man gearbox.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    no messing around perfect swap
    no engineer's report neither
    e.p.a. compliant aswell
    rego, no problem in any states/territory
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Check out my site for some details about the conversion. Home of the KERR BROTHERS!
    We had a donor car so all the parts were there. Ya need to put the EFI fuel tank in, fuel pump, filter, fuel lines (return line, but we put both in), then the rest is pretty straight forward.
    Pull the old motor out and take the trans off, change over the flywheel and clutch (you'll need a spigot bearing, but ur 173 should have one in it), put is all onto the EFI motor. On the end of the crank it has a dowl which needs to be removed, otherwise the flywheel won't bolt up. Once all that is done drop the motor in the car. Strip all the crap off the EFI wiring loom that u don't need, then plug it all in, and run the EFI harness back under the dash and plug it into the computer, make sure u also connect the tachometric relay, coz without this nothing will work. Run wires to the fuel pump, and the neutral safety switch wire just splice that into the purple starter motor wire.
    Check out my site for a bit more info on the wiring, and my forum also has some info too from when I was asking questions about the conversion.
    Pub24/7 and HDT202 are the ones who helped me through it. You can find them on my forum, or prolly better to contact them on here as they'd be online more.
  1. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  2. L36 GM motor?
    By HIROLLA in forum V6 Development And Modification
    Last Post: 17-04-2007, 07:02 PM
  3. VR motor & Box in VP
    By gazza140356 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2007, 06:03 PM
  4. VR motor into VL
    By cruzncommo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-01-2007, 10:32 PM
  5. l67 motor
    By kyl'svs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 10:07 AM
