Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: VK turbo
    VK Executive
    Jul 2008
    Default VK turbo
    Just a few pics of my daily driver. Its not a show car just my toy. It started out as a 3.3 EST auto sedan and is now a twin carb turbo 5 speed. It is standard in aperance sept for a bonnet scoop. I really didnt want the scoop but the carbs dont fit under the bonnet. I still have original bonnet in the garage. I want to fit EFI in the future and am looking for a 3.55 or 3.36 LSD 10 bolt salsbury for it, and have a wolf3D ver4.4 that I want fitted asap, but with quotes around the $800 mark to fit it Im waiting to have the cash spare or looking for someone to do it a bit cheeper. Once the wolf is fitted Ill get a bit more closer to fitting EFI as well. Turbo is rated to 650hp twin carbs are Mike Vine Hi-flow jobs rated at 400hp it has about 350 rwhp ATM.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    totally cool mate!
    bet you get a lot of confused looks when you WHSSSSSSSSSSSSSSSSSSSS past people
    There's a bloke that's recently run a DELCO ecu (same as in VN/VP) with a holden straight 6.. could be a good way around the 800 dollar cost of a wolf
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Delco VL goodness-ness
    that might give you a bit more info on it.
    the biggest hurdle would be the dizzy/crank sensor.. the rest should just be cut'n'shut wiring loom spec!
    VK Executive
    Jul 2008
    Default VK turbo
    Cost heaps I really got no idea how much because Ive been putting it together over a couple of years. I took the original Rajay turbo into turbotech for some new seals and bearings couple years back and they gave it back to me in pieces in a box and said parts are no longer available for them I came across a new one that was meant to go in an airplane so stripped it of all its new bits and rebuilt mine. A Garrett Strata would have been cheaper and easier but I have a VK EFI intake manifold that has been modified to bolt onto this kit, has also got modified fuel rail and throttle body to suit as well. EFI would be too difficult with a strata; if I had to take a guess maybe $5000
    VK Turbo build
    My Forum
    Email me
    bolby's Avatar
    bolby is offline werd
    VH SLE 202 turbo
    Apr 2006
    endeavour hills, melburn y0
    efi with stratta isnt possible unless you mod up an EFI inlet manifold, even then you cant run blow through with a cooler, so not much point.
    looks good man.
    i had a stratta II kit on my built red 202. was good fun
    best of luck with the rest of the build
    VK Executive
    Jul 2008
    Default EFI on the topmount turbo
    It wasnt easy to fit the EFI to mine either but alot more possible than the stratta, Im not a big fan of strattas I have a mate that has one and it doesnt pull nearly as hard as mine, but it is carbed a bit different as he uses a 48mm DCOE webber. Im posting up some pics of my EFI dummied up onto an old head Ive got lying around
    As you can see the manifold needed extending, the fuel rail is fully custom as is the throttle body. I have a new set of 600cc injectors from injection perfection to go in it as well. I bought a VK calais wreck that still had all the EFI gear I need for the conversion including tank and lines. so they are in the shed waiting. Fitting the Wolf3D is the next thing I need to do while its still on carbs. Trying to get more than 8psi of boost using the HEI is prooving to be tricky. Ive got a Vacume advance module off a datsun turbo fitted to my HEI dissy atm that retards the timing under boost but not enough to go over 8psi without detonation. It has a real fine line between pinging under boost due to too much advance and backfiring under boost due to too much retard. I have all the EST gear fitted, ie crank trigger, water temp sensor, manifold pressure sensor still hooked up, from what Ive read Ill need to fit a coil igniter to use the wolf and the HEI will get flicked in favour of an EST dissy. Im tempted to try fitting the wolf myself, I just want to cut off the original EST plug and solder on the wolf one to the original loom so it will all still look stock. I have NO previous experience with EFI computers so I am a little reluctant to try it, so if anyone with experience has advice Im all ears, my own advice is to save the $800 and take it to a shop
    Last edited by hiy_po; 09-08-2008 at 11:41 PM. Reason: pics were a bit big shrunk them
    VK Turbo build
    My Forum
    Email me
    VK Executive
    Jul 2008
    Default Wolf3D
    the wolf in the pic isnt the one Im using. I have a ver4.4 with hand controler.
    VK Turbo build
    My Forum
    Email me
    VK Executive
    Jul 2008
    Default Update to VK turbo
    Ive made a few changes to the VK thought I would post them up.
    Took off the CD175's and added HIF44 1 3/4 SU's.
    Added a adv/retard control to the HEI
    Added a boost controler and gauge.
    Coming soon is a pair of ram tubes for the carbs and an ICE ignition.
    I am also looking for a 3.36 or 3.55 10 bolt LSD to suit VB-VK in good condition around Perth
    VK Turbo build
    My Forum
    Email me
    eko's Avatar
    eko
    eko is offline 3kO
    Soon to own vb commy end of year
    Aug 2007
    South Eastern Suburbs
    Hey guys just a quik question with that turbo setup putting da carbs infront of the turbo neck i was planning on doing it on my vb..is it possible to put a intercooler setup on that ype os system coz some people say its not healthy dis dat....cheers ??
    VK Executive
    Jul 2008
    Is it possible to add an intercooler? Yes it is BUT it puts a mix of fuel and air through the cooler and thats not a good idea. Intercoolers ar made to cool air only and having an intercooler full of fuel is like a bomb waiting to go off if ever anything punctured the intercooler I wouldant want to be anywhere close by or in the car if it ignited. So in sumary is it possible yes, Is it practicle or advisable NO.
    Meth injection after the turbo is the way to go with these setups. Get the cooling without adding lag.
    VK Turbo build
    My Forum
    Email me
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    awww ok i get ya and also is there any way u can install a turbo system on without connection the craby to the turbo necj or do u have to?? coz i think some guy had did tthat ona a vc commdoroe he didnt have the carby connected up to the turbo neck
    VK Executive
    Jul 2008
    I think you are asking about a blow thru system. Blow thru has turbo 1st then carb 2nd and carb is usually bolted to the manifold in its stock position. My system is a draw thru has Carb 1st turbo 2nd and manifold is just a joiner to join turbo to engine intakes. Blow thru does have advantages over my setup as you can run an intercooler between turbo and carby and as long as your carb is modified to suit blow thru (not all carbs need to be modified for blow thru but holley's do) the system can be easier to install and give impressive results. My particular setup is not very suitable for a blow thru setup as the turbo takes up the space were the carby would be sitting. But if you have a custom manifold (usually a low mount) it can be easlly done. Below is a pic of a blow thru setup I started but never finnished
    VK Turbo build
    My Forum
    Email me
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    ahhhh k thanx alot mate u answered ite wat i was looking for hehe looks goood btw
  15. #15
    Sep 2008
    Default intercooler and injection on Strata setup
    You can inject and intercool a strata its just more work and modifications. No such word as CANT it just gets harder thats all! You would need to modifyy the the intake to have it on the other side cut and shut a bit of ali welding thats about all there is to to it for intercooler injection may be a littlee more problematic but can be done.
    Cheers fergy
  16. #16
    Jo3_Blo's Avatar
    Jo3_Blo is offline HZ Holden Fanatic
    WB 1 Tonner, VS Ute
    Jun 2006
    Damn, what a sleeper. Even the old hubcaps and everything. Looks entirely original other than the bonnet scoop.
    Motor looks wild too, good work man.
    FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
    http://forums.justcommodores.com.au/...ressively.html
  17. #17
    VX Acclaim Series I
    Apr 2008
    RADelaide
    ZZZZZZZZZZZZZZZZZZZZZZZZZTUTUTUTUTUTU
    beautiful mate, abosolutely beautiful
    VX Acclaim
  18. #18
    VK Executive
    Jul 2008
    Thumbs up Fergy haahaa welcome
    Quote Originally Posted by Fergy View Post
    Cheers fergy
    Yer Fergy but your a wizz mate Im sure you will actually do it one day too. When we both have EFI on our turbos we will have to have a think about intercooling. I do think about meth/water injection. It would make both our cars a bit more boost friendly while they are still on carbs
    Quote Originally Posted by Jo3_Blo
    Id love to loose the Bonnet Scoop but the tops of the carbs poke through the bonnet. I still have the original bonnet waiting to go back on once the EFI is installed. She'll look much better then.
    Thanks Chris The Slayer, makes me want to go and wash all my dirty hand prints off it.
    VK Turbo build
    My Forum
    Email me
  19. #19
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    ju another quik question if you have the inlet manifold and the exhuast manifold on da oder side can u hook up a intercooler that wayy ???
  20. #20
    VK Executive
    Jul 2008
    Default intercooling
    Quote Originally Posted by eko View Post
    You can intercool regardless of what side the manifolds are on. The Important thing is to have air going thru it and not fuel. Doesnt matter where you have your manifold as long as the carby or fuel injectors are after the intercooler.
    An intercooler is not the be all and end all of turbo charging holden 6's. Your combustion chamber is real important, your ignition setup is critical and getting the right static compression ratio to start with will allow the boost you want to run. A copper head gasket and a set of head studs will hold it all together. Yella terra once cast a head with a 68 or 70 cc combustion chamber getting one of those is a real good idea. good luck trying to find one but, they are pretty rare these days.
    VK Turbo build
    My Forum
    Email me
  21. #21
    vh 3.3
    Jan 2009
    Default turboing my vh
    hey im 19 and own a 1983 vh sl im still on my p's but wanna start building a motor 4 wen i get my blacks. I wanna go with the 202 turbo but ive seen it done with the fuel injected vk motor and the carbied 202. Im a bit confused on wich 1 to use coz i recon the fuel injected 1 will make more power but have hurd tht the injected motor isnt very reliable can any1 give me some advise on wat i should do and around how much it should cost?
    cheers
  22. #22
    VK Executive
    Jul 2008
    Default turbo 202
    I agree EFI will be an improvement over the carbs, but that said this engine gets scary under boost with carbs. I dont see how an EFI engine is any different from the carb engine or the blue motor for that matter. The black motors ( EFI or EST ) have a better flowing head than the blue, and the EFI even had sodium filled exhaust valves. The cam in the EFI is a good turbo cam as well. The red motor is the weakest of the bunch with its crank producing a torsonal vibration at 5500rpm and its rods arent as strong. The heads dont flow as well at low lift due to the low pressure caused by the siamesed ports.
    What it costs is up to the individuals budget, you can use a stock motor with a decomp plate or spend as much as you can on working the engine for balance, strength and more air flow.
    VK Turbo build
    My Forum
    Email me
  23. #23
    VK Executive
    Jul 2008
    Default update
    fited an alloy air duct to the carbs. its rounded inside like ram tubes and will allow me to attach a pod once the battery is out of the way.
    Modified the dump pipe to clear my EFI manifold. One less obsticle to the EFI conversion.
    My next big thing will be to change the fuel tank for an EFI one and change the supply lines to the ones I have off the EFI calais.
    Thanks goes out to Fergy who came over with his welder and welded up the new dump pipe. Was no easy task and he kept at it the whole day and the job at the end is faultless. Thanks again mate.
    Also thanks goes out to Fergy for the use of his BTM. Been experimenting with the different ways of firing it and have had some very impressive results. The difference these things made to my engine is huge. Still got a way to go before Ive got it all sorted. Im going to dyno it on the 28th of this month so Ill have a RWHP figure if all goes well after that and its tuning time up untill then
    VK Turbo build
    My Forum
    Email me
  24. #24
    Nov 2007
    VP Ser2 BT1 355, 3800 conv, 3.45 IRS
    May 2008
    Traralgon, Vic
    Mate this thing is terrific!! Love those that look outside the square.
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  3. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
