Page 7 of 7 FirstFirst ... 34567
Results 151 to 168 of 168
Thread: My VK Project
  1. #151
    Pez's Avatar
    Pez
    Pez is offline Reppin
    VK
    Feb 2009
    Northern Beaches, Sydney
    im glad its easy than. im going to hook it all up tonight looks pretty easy with the bullet connections.
  2. #152
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    just one thought though, they dont really include any flexible conduit with it. i wasnt happy with how the wires bent over on themselves when you closed the door. eventually they will snap from all the opening and closing, so (and feel free to not do this cos' it is a little dodgie) i drilled a 8mm hole on the door and sealed it with a grommet, then drilled a 12mm hole on the A pillar and put a grommet in. then got a coat hanger and cut around 180mm and bent it in a curved shape which i wrapped into the loom really tight so it wouldnt move.
    the idea is that when you open the door, the 8mm grommet and loom doesnt move at all, but the 10mm grommet allows the loom to slide in and out, the curved shape is the angle the wire takes when the door is open. making sense? so that way the wire doesnt fold over, it rotates in and out of the A pillar. the only downfall is that the 10mm side isnt sealed against the weather, so it may get water in it.
    just a thought. you will understand what i mean when you get to that part
  3. #153
    Pez's Avatar
    Pez
    VK
    Feb 2009
    haha yeah reading it dont really get it. but im sure ill understand it a bit more when im putting it all in
    thanks
  4. #154
    ari666's Avatar
    1966 impala
    Mar 2009
    well somehow you have to get 5 wires (on the drivers side, the rest are 2 wires) out of the car and into your door, the best place is in the jam. the distance between the door and the jam when the door open is something like 70mm but when its closed is around 10mm, so your 70mm length of wire has to fold in half if both ends dont move. im suggesting that you allow one side to move backwards and forwards, so instead of folding over, it stays straight. either way, you still need to drill holes in the door to run the wires. unless you run the wires behind your door card, but that would look hideous and i would imagine will damage the card eventually.
    im doing a terrible job explaining myself
  5. #155
    Pez's Avatar
    Pez
    VK
    Feb 2009
    i kinda get it now. still havnt fitted it yet the car got painted tonight so looks like its tomorrows job then fit the car all back up.
    have you had any trouble with cutting out the locks on yours ari666?
  6. #156
    ari666's Avatar
    1966 impala
    Mar 2009
  7. #157
    Pez's Avatar
    Pez
    VK
    Feb 2009
    yeah but like with the whole locking system. if the central locking screwed up you wouldnt be able to get in aye.
    just wondering because i might do it to mine in a few months
  8. #158
    ari666's Avatar
    1966 impala
    Mar 2009
    well at the moment i have still got the drivers side barrel lock in so if i have a flat battery i can still use a key. i have a solution if you wanna shave the handles but you will have to PM me, cos im not posting it online.
  9. #159
    Pez's Avatar
    Pez
    VK
    Feb 2009
    tonight started fitting actuators took ages. back doors were easy but spent hours on front doors trying to figure it out. ended up taking window out and putting it straight onto lock.
  10. #160
    ari666's Avatar
    1966 impala
    Mar 2009
  11. #161
    Pez's Avatar
    Pez
    VK
    Feb 2009
    got them all fitted. not to bad when you figure out how to weld them. im looking for these rubber boots to put over wires which comes with new cars so wires dont get damaged.
  12. #162
    Pez's Avatar
    Pez
    VK
    Feb 2009
    all central locking is done and wires run. just gotta do a water test to check for leaks then carpet and seats go back in.
    pulled apart most of the 308 also. still gotta decide what i want to do with it before i take block down to get started. think 355 stroker.
  13. #163
    ari666's Avatar
    1966 impala
    Mar 2009
    sorry, i must have missed the bit where you got a 308... or i forgot... either way: do tell!!!
    355 will be hela fun, you got the dollars to complete it though? what are your ideas so far?
  14. #164
    vk,vk,vl
    Aug 2009
    Quote Originally Posted by ari666 View Post
    All you are doing is forcing the wires to bend at a different point.
    Better still, take some notice of how late model cars are built. I used the factory loom tubes from a late model Subaru. If you drill the hole in the pillar way higher (or lower) than the one in the door, the wire does not have to bend much at all, it basically rotates. You can then drill a big hole in both the door and pillar and fit the loom tube to run the wires through. It will be water tight too. It works for every other manufacturer in the world.
  15. #165
    Pez's Avatar
    Pez
    VK
    Feb 2009
    haha yeah i dont think i posted when i got it. must of been in hat stage when i didnt come on for ages.
    got a 308 out of a vl which was an old mans car so wasnt thrashed. some guy wanted to put 6 turbo in it so got it for 350 + case of beam.
    it was half pulled apart when i got it but all bits are there.
    ill get some pics soon.
  16. #166
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    interested in selling ur 208??? :P
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
  17. #167
    Pez's Avatar
    Pez
    VK
    Feb 2009
  18. #168
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Hey Pez,
    Just read through your whole thread mate, start to finish...
    You have choped and changed your mind abit on the v8...Lol..
    Good work on all of it though. You and your dad have done well.
    You should have a look at my vk I just picked up. Will be a show car when i'm done....
    Like the paint mate, looks good. Too bad about the rust and you didnt see it when you where painting the whole car and had the trim out..
    Top work and keep it up...Through some more pics up mate.
    Cheers Nackerz
  1. Project VEE EL
    By VL Berlina 5speed in forum VL
    Last Post: 12-12-2010, 02:07 PM
  2. Vc Sl/e Project
    By CORY in forum Projects
    Last Post: 10-02-2009, 09:07 PM
  3. Project: WMC
    By Niggadore in forum Car Audio
    Last Post: 18-07-2008, 01:26 AM
  4. My little project..
    By vkwalks39 in forum VB - VC - VH - VK
    Last Post: 11-07-2008, 06:47 PM
  5. my project vn
    By vn4play in forum VN - VP - VG - VQ
    Last Post: 27-01-2006, 12:00 AM
