hey guys n gals.
this i my Vk commo, its a 4 speed manual, carbied 202 black motor and right now it doesnt run
atm i suspect the carby is f**kedbecause all the plugs are sparking, and its happening in the right order at the right time, except it wont start up, with aerostart, it will kick a little but no more.
anyway, heres some pics:
Interior:
Back:
Shades:
Engine Bay:
YYYYYYYYYEEEEEEEEEEEEEEEAAAAAAAAAAAAAA!!!!!!!!!!!!
she runs
turns out the timing was about a 6th of a rotation out.
at the moment, its idling kinda rough...but idling non the less. and as soon as i open up the throttle to get the second half of the carby working, it starts to die a bit, so that side may need a tune, or just needs a decent clean up and a workout.
anyway, now that the beast runs..i can get it in and out of the workshop easily, and finally get to work on fixing it up.![]()
been slowly doing a bit of work on the vk after work some days.
decided to chuck some wheels next to it, which do you think looks better?
15 Inch 5 spokers:
17 Inch Shadow Chrome Starcorp Tracers:
also been fixing up the panels abit. mostly stone chips, and marks from bad driving or it being broken into
opinions?
i know this isnt the busiest of threads, but now that the holidays have come around and ive been able to work abit, i decided to get some new brakes for the vk and i wanted some advice...heres the goodies:
disc diff with slotted discs
vt front brakes on slotted discs
full set of lowered shocks and springs
and adjustable strut tops
also came with a VT master cylinder and brake booster.
could someone please shed some light on fitting the brake master and booster? or is there already a detailed thread hidding on the site somewhere?
and how do i remove the lower ball joints? the previous owner of these parts decided they couldnt be bothered removing them, so just cut the control arm in half with an angle grinder![]()
How to adapt the VT Master Cylinder to early model Commodores - calaisturbo.com.aucould someone please shed some light on fitting the brake master and booster? or is there already a detailed thread hidding on the site somewhere?
ive bought a holley 350 to go on the 202 for a bit, until i can find a suitable donor car.
just wondering if anyone knows what jets i should be using in it? completely stock motor...but anything is better than the rochester :P
it has 62s in it at the moment, and was jetted to suit some english 4.2ltr v8
im having a little trouble with the Holley 350. its all mounted and im pretty sure there are no leaks anywhere. when i turn the engine over, fuel comes pissing out the float bowl breather, and it wont start. tried spraying aerostart down the throat as well and still no luck. checked ignition again and its still working perfectly.
any ideas? do holleys have a fuel return?
ok, turns out it was flooding. somethings up with the float.
got it working okish now. not sure if its rich or lean, it backfired up through the carby hinting towards it being lean, but i think the jets are too big so im not sure.
also...some weird shit goin on with the harmonic balancer :S
see the grooves?
good job keep up the mods
coming up nicely
got the new harmonic balancer on today...no more knocking on the fanyes, it was quite f**ked
probably going to finally get around to putting the vt front brakes on this weekend...but plans being plans, they never come out the way you want them to
the holley is also almost dialed in. doesnt piss fuel out anymore, just needs the idle lowered, the mixture adjusted (playing with jets...yay) and a braket made to hold the throttle cable. starts up perfectly everytime atm.
thats ***ed up its good to see someone who dosent care how bad the car looks just see's the potential in it and put heaps of effort in
yep def good way to learn
im in need of a little help with the doors.
vl vk etc door hinge pins
its always those little things that pull you up.
EDIT: looks like that problem has been solved. thanks again guys![]()
it seems i really am getting serious with this project.
just went out and bought a T5 for the V6 when the time comes to putting it in.
no way am i putting an auto in
heres a basic rundown of the plans for the car:
- VN V6 and T5 manual - Done
- VN V6 K-Frame - Done
- VN V6 engine computer and loom - Have
- Front and rear lowered shocks and springs - Done
- Borg Warner disc diff - Done
- VT front brakes - Done
- VS V6 brake booster and VT master cylinder - Done
- VL slide lock doors - Done
- Central locking - Done
- Alarm + keyless entry - Have
- Relocate Battery to secure box in the boot - Have
- Wilwood brake bias tap when it comes time for shenanigans - Dont have
- Custom gauge cluster - Have Gauges
- Custom door cards based on stock items - Have spare door cards
- 4 Non ashtray armrests (there will be no smoking in this car!) - Have
- Bonnet gas struts - Done
- Delete antenna - Not done
- Cable release fuel cap - Have
- White venetians - Have, yet to be painted
- Respray in Chrysler intense blue (outer body work, door jams, engine bay. pretty much anything that can be seen without stripping the car to absolutely nothing) - this is really gonna break the bank...even with mates rates
ill add more as i remember it, but i think thats pretty much it. its gonna take a while, but what do you expect...pretty much rebuilding the whole car
more pics soon![]()
good work bud
