Hey Guys, I've been looking around for some info on doing a brake conversion on my 1983 VH 6cyl. I've figured on swapping front and rear with VT setup including the brake master cylinder but I can't find any info specifically how to do it. Found lots on VK but nothing VH. I'd be looking at getting the bits and pieces from a wrecker and freshening them up then fitting them. What will I need? Obviously a new set of pads and disks are on the cards.
Has anyone else done this and can they share their experiences. Or, in case I missed it, can someone point me in the right direction within the forums.
Thanks,
Lewie.
im running the vt upgrade on the front in my vh. you will need discs, calipers, pads, new brake lines(if there still originals), hub adaptors and new bearings. you can run it with a 1" master cylinder but a vt master and booster are slightly bigger and give a slightly better pedal.
check my site
i did the VE upgrade on my VP, LOve it, gotta put 17's or bigger wheels on tho, but they work mint..
they where a pretty straight swap pack i got came with hub adapters , discs, callipers and pads and new brake lines.
i didnt need to change my master or brake booster, mine works fine, but some have said they get a bit of extra pedal travel..
does the front hub adaptors change the offset of the wheel? i.e. does it make them stick out more?
No, they shouldn't. They fit on in lieu of the original rotors as they have integral bearings.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
My budget is not too flash. But what I lack in funds I make up for in patience. I was thinking about hunting around some wreckers for the parts I need and freshening them up as much as I can and handing them over to a pro if necessary. This project will be more of a learning process for me. Although it will be my daily driver when it's done.
What would I be looking at for a VE conversion?
They come in different size rotors and are different prices. What size rims do you have?
Only standard original rims. 15s maybe? What ever they came out with is what's on it at the moment. I know that will have to change though but I will buy rims to fit over the brakes when the time comes. I'll be putting in a V8 down the track so I'm upgrading with that in mind
in that case save for the ve brakes mine were 700 and something dollars, i think min wheel size is 17 inch , but never seen mine car pull up like this before, just about put me thru the windscreen lol - im in same boat doin up my car , but doin replacements with the upgrades in mind in the future
Each kit includes pads, rotors, calipers, brake lines, brackets, and instructions...
- 298mm Standard Rotors $815
- 298mm Slotted Rotors $855
- 322mm Standard Rotors $895
- 322mm Slotted Rotors $945
The VE kits for VT's are a bit cheaper than they are for the earlier models...
Thanks for that info glsrallysport. Are those prices for all 4 corners? And I'm guessing this is through your company. Does this include a master cylinder? Am I right in assuming the standard VH setup would not cope with this upgrade. Can this sort of thing be done in the garage?
Those kits only for the front. The kit is complete from RDA, but we're stockist of it. Doesn't include master as I don't beleive it needs it with the VE calipers (which aren't as big as VT).
Should be a fairly easy talk in a garage if you're handy. It's a bolt on kit so no modification required as far as I'm aware.
Have a squiz here:
http://www.rdabrakes.com.au/images/s...e_kits_web.jpg
Hi all, just a quick update and question.
Firstly I have a VK 10 bolt Salsbury diff, discs inclusive, with new bearings and seals. VH handbrake cable for discs. A pair of adapter hubs for the front with new bearings. Almost new VT front calipers and SS master cylinder and booster and, when the tax cheque arrives, new slotted rotor front and back.
Now, my question is will the Original VT brake lines be suitable to install with this setup or do I need different ones? I ask because I've heard of having to change the break lines when doing this conversion but I don't know if this is from the VH ones to VT or something different.
"Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
i dunno but i did the vlt upgrade and my car pulls up pretty quick
Does anyone know if I can use the VT hoses on my VH?
call kent brakes port road woodville pk he should be able to help ya he gets brakes in cheap to
Gurus,
I finally got around to putting all the parts I'd gathered on to complete the front VT brake conversion on my VH. Thought I'd share my experiences. I did end up buying some parts that didn't/won't be going on but I'll mention them as I go.
Parts:
2 x VT slotted front rotors
2 x VH slotted rears
QFM HPX pads to suit + postage to Adelaide (very quick mind you!) $508 BIG thanks to GSL Rally Sport for those!
2 x adapter hubs inc bearings and seals $262 from eBay
2 x braided lines $84ea
Full set of front and rear VT calipers, SS master cylinder and booster $300
re-flaring the ends of the rigid lines to suit the master cylinder $38
VS plastic booster from U-Pull-It $50ish
The battle... I can't figure out how to inbed the pics so I'll have to attach them one by one. I'll describe the process and the pictures should go hand in hand or at lease fill in the gaps hopefully.
1. Car jacked up and on stands. Wheels off and ready for action.
2. Caliper removed via the 2 bolts from the back. Caliper moved out of the way with lines still attached to save on mess.
3. Remove the cap over the locking nut, remove the pin, nut, washer and then you should be able to pull off the rotor. You will have have a small bearing at the front that will fall out and onto your trackies leaving a big green greasy smudge that will spread, and a larger bearing at the back. Also a large black rubber seal. Pull all of these off and discard.
4. Give the exposed shaft (dunno what it's actually called) a good clean and inspect for damage.
5. Install new rubber seal and pack bearings with grease. Install bearing cups into adapter hubs. They will be tight!
6. From here i test fitted the new caliper and found that I needed to mod it slightly. I had read this in another thread so I was half expecting it. The holes in the caliper bracket are the right distance apart but the way the brackets have been made stops them from sitting flush against their mount. You need to file/grind off about 2-3mm of material as shown in the pic off one end.
7. Once you know the caliper will fit install the large rear bearing, the hub, the smaller front bearing, the washer, the nut then pin in place. I tightened the nut to finger tight then tightened a little more to line up the holes for the pin.
All downhill from here...
8. Stick your shiney new rotor on and replace the new caliper with the two bolts removed earlier. (make sure that the bleeding nipple is at the top. if it's not swap sides!)
9. With the bottom bolt removed that attaches the body of the caliper to the bracket (that screws into the back of the slides) pivot the body up so you can install your new pads.
10. With the new pads in close the caliper, replace the bolt and you're almost done.
The brake lines...
VH lines were dead. VT lines will NOT fit due to the not quite being long enough AND having the wrong flare AND the wrong attachment bracket where it joins the cars rigid lines. There is a specific shape required for the line to sit into a cup and be secured in place with a slide thing. This was one of the reasons why I went for the braded lines. I did try to make the VT hoses fit but it really was doomed from the start. My advice: don't bother. They're too important. Get some newbies. Luckily the brake place up the road from me had all the dimensions in their computer. This info includes not only the fittings required but the lengths above and below where the line runs through the bracket on the shock absorber and the degrees that the top fitting it off from the bottom so the lines won't have to be twisted changing the length. They made it a very painless process. PWR brakes Gilles Plains SA if anyones interested. Good bunch of blokes and, as you can see, they know their stuff.
The Booster...
I had originally intended on using the metal VT Booster I had bought with the rest of the calipers and master cylinder but I'd been reading about how people had to heavily modify the mounting bracket. I have neither the skills or the tools (or the time) to do this so I found out that the VS booster would go in without any mods at all. I eventually found one at U-Pull-It that looked fine and made it my own. After a bit of trial and error I managed to get the old booster and master cylinder off. In retrospect it is probably easier to remove the booster while the master cylinder is still fitted via the 2 nuts in the footwell up next to the steering column. Needless to say I got there in the end and all was removed. I was a litttle more than impressed when I found that the VS booster bracket fit perfectly on the firewall without hitting anything. Now, on the booster itself where the master cylinder goes there is a small pushrod with a hex nut sticking out. I believe you can buy adapters for this to fit the VT master cylinder on but I opted for the option I saw in another forum on the net. I got my trusty dremel and ground off the head of the nut so it was flush with the top of the shaft it screws into. Great success. The master cylinder sits flush. From here I installed the master cylinder to the booster and, with the help of some wire, I poked the thread through the fire wall and held it in place while I got the nuts onto them next to the steering column. This can be a little fiddly but you need them. Get em on! The pin for the brake pedal was re-inserted into the pushrod of the booster and everything was tightened. On the front of the master cylinder there is a small bracket that attaches to the tower on the drivers side. The VT didn't have this so I swapped over the ends and re-fitted the bracket. Each to their own though. Also you can adjust the height of the pedal by drilling another hole in the push rod of the booster. Drilling another hole (10mm i think) right next to the existing one will slightly lower the pedal. I was happy with where mine was so I didn't bother.
The rigid brake lines...
The master cylinder I wanted to fit was a 1 1/4 in bore and from a VT SS. It also has a single flare as opposed to the VH double flare (i think. Or the other way around). I had 2 options. I could try to track down line adapters to screw into the cylinder saving me the trouble of taking the rigid lines out of the car or I could take the lines out and up to the good guys at PBR. I hated the idea of using the adapters and coupled with not being able to track any down in the 3 minutes I dedicated to the task I set about taking all the rigid lines out. It wasn't anywhere as hard as I thought. It was just a case of taking my time and moving things out the way where necessary. Obviously the lines for the back brakes took a little longer to get our but I got there in the end. No sweat. The re-install was no more painfull then before plus PBR has replaced 2 of the rounded threaded portions I'd stuffed prior.
The final stretch...
Rotors calipers and braided lines are on and tight. Rigid lines are re-flared and back in. Booster and master cylinder is bolted up and ready to accept the rigid lines. With the lines going into the master cylinder I had to manipulate them a little to get them to sit right and not have any too sharp curves in them. And not brake them as I was putting them in. This took a little of patience and care to thread them through eachother but I'd come too far to get heavy fisted and snap one. I think I would have sh!t a kitten at this late stage in the game. With the rigid lined installed and tight all that is left was to bleed the brakes and try them out. Bleeding went fine (after I tightened up 1 fitting a little more) Time to try them out.
The result...
I'd heard people saying what a massive difference they've made. how they can pull up sooooo much better and how effortless the upgrade makes things. Now that I've done it I can safely say that those people...... are absolutly fuggin right!!! Holy cow! I am in heaven! I have literally come to a complete stop going down hills that I would normally ride my brakes down to stop at the traffic lights at the bottom. I'm VERY impressed with the result. Even the inertia of you initially putting your foot on the brakes is enough to slow you down even more. I am actually a little scared to push them too hard for fear of my wheels going in separate directions! I sh!t you not! I know there are cheaper ways of doing what I have done but I'm glad I did it this way. A little problem solving never hurt anyone and I learn't plenty along the way. All up, if I had all the parts that I needed there and waiting you could easily get this done in an arvo. Or a weekend with a few beers.
Now, I have a salisbury diff in the garage with another set of slotted rotors, QFM HPX pads and shiney calipers to replace the tired rusted drums I have on the back at the moment. Just need the right tail shaft! That's my next mission. Anyone got a VK V8 rear section!!
Hope this write up helps anyone considering or doing this mod. It's well worth it. Also, I know that I have spent more on the brakes than the car cost me and it's not the best looking machine but I have plans. Big plans. It was my Grandfathers car so this is only the begining.....![]()
if that combo doesnt work for you i highly reccomend lucas pads, only about 60-65 a pair, the fronts are only needed, i raced on them at wakefield and never got any brake fade from my ss ute, and run them in every car, there fairly soft=dusty, but also dont chew the rotor out, also do you have a 1"master??
Not in the equivalent full face pad they're not... The standard pad you're talking about is a GDB7587. The equivalent Lucas pads to what we've supplied is a GDB7584, and will be WELL over the $100 mark...
The Lucas are an excellent pad though, and I personally used to run them in my Samara rally car before we got onto QFM. Good for 650 degrees (so'borderline' track capable), and are a good high performance street pad, but most people doing track work will need something better.
Stepping up from Lucas would be the QFM A1RM (Ferodo DS2500 equivalent), and at $119 will still be cheaper than the equivalent GDB7584 Lucas, which we carry on the shelf for $129.
