Results 1 to 4 of 4
Thread: Vk 308 water problem
    VK 308 commodore
    May 2009
    Default Vk 308 water problem
    ok i have a major problem. water is getting into the second cylinder and straight out the exhaust and a fair bit of water came out after 20 seconds running time and water came out of the spark plug hole. we have rebuilt the head and put it back on but still has a problem. any help? P.S. just gotta say that it takes 5 minutes for all water to be gone and car to overheat, way to rapid HELP
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    A cracked bore can also cause this.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    was the head pressure tested? cause it sounds like there is something more serious than a head gasket going on. Maybe a cracked water gallery that is dumping the water right into the cylinder.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    VK 308 commodore
    May 2009
    Yeah we thought that it would also be a cracked bore so we are going to get it checked. oh well, new engine
  1. Water Problem
    By MUT4NT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2008, 01:34 AM
  2. Potential VX Water Pump problem
    By Nuffy in forum General Discussion
    Last Post: 28-04-2008, 01:57 PM
  3. Trimatic Transmission Problem - Water in the Torque Converter
    By amen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2007, 05:03 PM
  4. water problem
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2005, 10:38 AM
  5. water problem
    By bigazza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2005, 09:28 AM
