Results 1 to 10 of 10
Thread: Indicator Stalk
    May 2005
    Default Indicator Stalk
    Hi,
    I broke my old indicator stalk and not knowing too much about cars I was wondering how much difficulty there is in replacing it with a new one. I bought a new one a few weeks ago, it's just a matter of figuring out what exactly to do.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Pretty easy but you have to take the steering wheel off ....mark wheel to shaft first so it back on right and also undo the screws holding the shroud under the alloy housing and disconnect the wiring connector undo the single screw that holds the stalk to the mechanism and thread wiring and connector between indicator mechanism and alloy housing.Reciprocate
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Just one tipwhen you undo the nut on the steering wheel remove the lock nut then loosen tot he end of the thread the main nut but DO NOT remove the nut. When you pull on the steering wheel to break the friction join it wont smack you in the mouth
    It should be pretty straight forward from there
    May 2005
    lol, speaking from experience are we?
    I'm gonna do it tomorrow when it's not so dark.
    May 2005
    Also, just one more quick question. Should my head unit not fit properly in the dash? It seems extremly tight.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Nah I have always done it that way, its the way my dad showed me. I have however seen someone do it without the nut they nearly ended up on the back seat with a rather sore face
    What sorts of head unit?
    I fitted 2 pioneers to my cars both fitted nicely no problems.
    May 2005
    hahaha.
    Its a Panasonic CD/MP3 player. Just a cheapie. I think I got it for about 200 bucks.
    May 2005
    And another question to add to that...lol. What do you think about these sorts of car audio packages that sell on ebay reasonably cheap?
    http://cgi.ebay.com.au/ws/eBayISAPI....781153688&rd=1
    At the moment I've got 2 6x9s in the back running. Would one of these improve what I have by much? They sorta look cheap and nasty...but not having a endless supply of money it looks like quite an attractive option. Should I buy or not even bother?
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    Follow vkberlina's tip on removing the steering wheel - I joined the sore face club when I first did mine.
    As for the head unit, it's a standard DIN size in that model commodore and it should be a snug fit. But you may have trouble with the depth of the hole depending on how the ducting and wiring is positioned in the rear of the dash.
    May 2005
    ahahaha, maybe you shouldn't have told me so you could have a good old laugh then
    I got it all off, all went good. Thanks for all the help guys.
  1. indicator stalk
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2007, 07:34 PM
  2. Indicator stalk VT
    By Nod in forum Electrical Wiring / Questions
    Last Post: 03-03-2007, 11:14 PM
  3. Indicator Stalk
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 03:04 PM
  4. indicator stalk
    By filtnineee in forum Electrical Wiring / Questions
    Last Post: 29-01-2006, 03:53 PM
  5. indicator stalk
    By junglepatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2004, 09:34 AM
